kartin
| posted on 19/2/16 at 10:29 PM |
Weld-on steering hub - but not quick-release
I am converting my corolla-based CEC to BEC and need to re-route the steering. Rather than try and re-use the Corolla shaft (heavy, and I don't
need the controls) I'm thinking of starting from scratch with 19mm (3/4" generic shafts and UJs. I plan to use an OMP wheel or similar.
My problem is the interface from 19mm shaft to steering wheel. I don't really want a quick-release hub so I'm trying to find a permanent
weld on adapter. I've tried searching on forums and web for "steering hub", "steering boss" and "steering
adapter" but all I can find are either quick-release or for karts.
Any suggestions? Thanks...
Doctor Derek Doctors
| posted on 19/2/16 at 10:41 PM |
JJC do a chunky weld on quick release boss for about £20 which has enough material to drill and tap a lock screw into to make it solid.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
russbost
| posted on 20/2/16 at 10:00 AM |
We do one which has the standard OMP, Sparco, RMD bolt pattern, it's pre drilled & tapped in either 4 or 5mm steel with a centre hole,
It's not something we advertise as used really for our own cars, but we do sell a few to customers who buy steering wheels from us, they are
£12
I'll try to get some pics/dimensions sorted out, if I've not posted them by Monday give me a kick!
