jps
posted on 5/7/16 at 08:37 AM |
Panelling/flooring - what order?
Maybe i'm being thick - but I can't help but think that if I fit my floor first, i'll really struggle to get good square on access
to drill and rivet the tunnel side panels...
So - do I need to panel the sides of the transmission tunnel before I fit the floor? Or will this cause me problems I haven't forseen?
posted on 5/7/16 at 09:11 AM |
On my MK Indy I fitted the floor first, then the interior panels. I did buy a right angle drill chuck to improve access when drilling the interior
rivet holes though - about £15 IIRC - not used it since though.
Brian R
posted on 5/7/16 at 09:29 AM |
Drill everything first and dry fit the panels with cleco's or similar. You can then de-bur and tidy the panels etc before you fit them
permanently.
roadrunner
posted on 5/7/16 at 11:34 AM |
As already said. Floor first. The tunnel panels are easy to sort later on in the build.
Bluemoon
posted on 5/7/16 at 11:40 AM |
permanently.
This the best option... Saves time in the long run..
posted on 5/7/16 at 01:44 PM |
This is the chuck attachment I bought...
RIGHT ANGLE DRILL ATTACHMENT CHUCK KEY ADAPTER 3/8" DIY TOOL ACCESSORY CORDLESS
Phil_1471
posted on 5/7/16 at 05:26 PM |
Fit the stuff first that you least expect to want to take off in the future!
You can live in a car but can't rally a house
jps
posted on 6/1/17 at 10:23 AM |
Quick bit of feedback - I used this link to buy the same right angle drill attachment. I was not overwhelmed by the quality - although I appreciate
you get what you pay for - there is a fair bit of play in the chuck. That said, I don't know how much it is impacting on the actual hole I am
getting - and the clecos still fit snugly so i'm assuming it will suffice.
Thanks for the recommendation Nick!
posted on 6/1/17 at 11:04 AM |
Still have mine and it works fine for me. Yes there is some play in it, but it seems to drill holes OK. From experience you have to hold it pretty
tight in use to avoid potential damage to yourself or surrounding materials.
