jps
| posted on 22/12/16 at 09:45 AM |
Rivet suppliers
I know there have been several threads already about this over time - just looking for the most up-to-date recommendations on suppliers for rivets.
Based on what everyone else has posted on various threads I am looking at getting:
3.2mm sealed rivets with a grip length suitable for 3.5mm (16swg-1.6mm tubing / 1mm alu / 0.5-1mm for PU) - for interior panels
4.8mm sealed rivets with a grip length suitable for 5.5mm (16swg-1.6mm tubing / 3mm alu / 0.5-1mm for PU) - for floor
4.8mm... etc - but countersunk (for the outside edges of the floor where i'll be putting GRP panels over them
Rivets will be alu/mandrels will be alu - i'll be blobbing them in PU before fitting to minimise steel/alu contact
Tried the local fasteners suppliers, they didn't have anything equivalent - so it looks like i'll be buying on-line....
Recommendations for where to getr them from please!!
loggyboy
| posted on 22/12/16 at 10:24 AM |
Was few years ago but I went to these guys as I worked not far from them at the time.
http://www.zygology.com/store/pc/viewcategories.asp
Big selection and good price.
I simplified and went with 4mm throughout, domed and counter sunk, both sealed, paid about £30 for 500+.
Mistral Motorsport
| posted on 22/12/16 at 10:25 AM |
I used sealed pop rivets for my MK Indy build - felt more comfortable reducing the chance of moisture getting inside the chassis tubes.
A quick Google shows to following...
http://www.bralo.com/en/products/non-structural-blind-rivets/sealed
x_flow57
| posted on 22/12/16 at 12:35 PM |
I have used D J Evans in Bury St Edmunds for yrs.
They have always been more than willing to help & have had whatever I have needed in stock or available quickly.
They also have a massive range of fasteners, nuts, bolts, washers etc.
You can buy what ever quantity you need, if you only need one you buy only one.
No plastic packs with half a dozen items at an extortionate price..
They aren't that far from you.
NTDWM
HTH
Nick
jps
| posted on 22/12/16 at 02:07 PM |
NTDWM
HTH
Nick
Cheers Nick - good to have a local recommendation - i'll check those guys out.
Bluemoon
| posted on 22/12/16 at 04:49 PM |
I used Avex multigrip, much better than the DIY pop rivet... Worth checking out.
geoff82
| posted on 22/12/16 at 10:30 PM |
Rivet Suppliers
D J Evans also have a depot in Ipswich which could be closer for some you out there.
Farthing Road
Ipswich
ip15ap
01473 747100
rdodger
| posted on 22/12/16 at 10:33 PM |
I used these guys. Very happy with the quality
https://shop4fasteners.co.uk/fasteners/rivets/blind-rivets.html
