K19
posted on 13/4/17 at 03:24 PM |
Interior Corner Edge trim
Hi all,
First post here, just bought a part finished MK Locost, I'm currently looking to do the trimming in the interior as per the IVA. Specfically the
central section that has a sharp 90 degree corner. I'm not sure what would be best to put along that edge, is
THIS the stuff i'm looking for?
Below is picture of piece i'm trying to trim
Thanks in advance
James
Edwardo
posted on 13/4/17 at 04:24 PM |
I've seen quite a few people use this type of stuff :-
http://www.carbuildersolutions.com/uk/wing-piping-14mm-tail-per-metre
They 'sandwich' it between the top plate and the sides so that the round bead runs all along the edge.
K19
posted on 13/4/17 at 05:36 PM |
Thanks edwardo, that stuff might fit the job without me having to do much work!
Rosco86
posted on 13/4/17 at 08:50 PM |
If it's for IVA you would be better with a bigger diameter on the round section, I think you can get 6mm, it's called p section if you
have an eBay search etc
My Build Thread
Bluemoon
posted on 14/4/17 at 06:59 PM |
Hockey stick aluminium extrusion. Used on horse boxes . Or tadpole trim, woollies trim has both types I think.
