Stuart Walker
| posted on 30/4/19 at 05:54 PM |
Upper seatbelt mounts
Hi all,
After a few years away from the car I'm now back and having a great time sorting it out. One of the original SVA fails was on the upper seatbelt
mounts. Looking at them now they are clearly no good as they are, so I'm considering the best way to improve them and would be interested in
what anyone else has done.
The current situation is little box section stumps welded to the horizontal chassis rail behind the seats, with captive nuts welded inside each stump.
My plan is to get rid of the captive nuts and use longer bushes instead, but I'm wondering whether to go through the existing stumps and the
horizontal chassis rail, or whether to weld the bushes behind the stumps. In either case I reckon I will go for long bushes (is this still the right
term when they are this long?!) and also weld them onto brackets on the diagonal chassis rail.
I will also, as recommended by the original assessor, triangulate the stumps with some box section angles back to the chassis rail behind. My
questions for anyone who might've been in a similar situation are...
Are the long bushes down to the diagonal rail worth doing?
Through the stumps or behind the stumps?
I've made some pictures in a CAD program called Publisher which hopefully shows what I'm on about. I guess I'm probably looking at 1
or 1+3 hybrid, but open to suggestions! Blue /green is current, red is new
Any thoughts?
PS. No need to tell me how stupid the original version was, I'm well aware
[img] seat
beltmounts_april19 by Stuart Walker, on Flickr[/img]
Stuart Walker
| posted on 30/4/19 at 06:59 PM |
Should also have said - I've got two roll bars (the cobra style ones) hence the extra plate on top of the chassis rails, but can't do the
roll bar seatbelt mountings.
Mr Whippy
| posted on 1/5/19 at 05:15 AM |
Is this how it looks?
Personally I'd weld a new bar between in the inside of the hoops and fix the belt to that...it will be vastly stronger than your other
suggestions
.JPG)
pewe
| posted on 1/5/19 at 09:41 AM |
Mine used the vertical towers with angled braces back to the horizontal rail behind - similar to your top right but without the verticals below the
towers.
I worked on the basis that manufacturers use relatively light weight mounts into thin steel for their seat belt anchorages and those will have been
worked out scientifically - we hope!
The sst involved will be more than capable of retaining a human.
All rather unscientific I know but reckon it's over- engineered for the job.
HTH.
Cheers, Pewe10
| posted on 1/5/19 at 09:59 AM |
These were the upper harness mounts on my MK Indy, which passed the SVA without any issue...
  MK Indy harness fixing point 2
[Edited on 1/5/19 by nick205]
Angel Acevedo
| posted on 1/5/19 at 11:05 PM |
I don´t think thr long bushes are doing any work at all.
Most of the load on the Shoulder Harnesses will be tension on the rear-front direction.
The inclined part may be replaced with flat bar and wrapped around the rear horizontal member to increase weld area.
A hole the same size as the mounting bolt would be enough as it will see only tension onte aft-fore direction as above.
All loads (or most of them) on the Down-up (Or Up-Down) for that matter will be taken by the lap belt and the crotch straps -if installed.
My uneducated opinion only.
Regards
AA
40inches
| posted on 2/5/19 at 08:29 AM |
Mine same as Nicks, but I took the strengthening bracket from underneath the box section.
The examiners at the Nottingham IVA centre paid particular attention to the rear belts mounts, and said this type of fitment was fine.
Stuart Walker
| posted on 2/5/19 at 09:05 AM |
Thanks all. Hopefully get it sorted this weekend - that will be one of the major jobs out of the way
I couldn't see your picture Mr Whippy, but I have tried to avoid involving the roll bars as if I did I think I would need to modify where the
hoops meet the chassis in the middle - at the moment they are welded to a plate welded across the two horizontal rails. I thought I might end up
making myself more work (i.e. having to add more verticals), but I see your point and will give it some thought. I can't picture what support
there is below that horizontal rail without looking at the car.
Thanks pewe - I might go for something like that. I assume you used bushes inside the box section?
AA I agree they don't add much, though maybe the whole thing might pivot at the top chassis rail in the event of an accident and perhaps the
lower fixings could prevent that?
And thanks Nick / 40inches - great to see some finished and successful versions!
40inches
| posted on 2/5/19 at 09:07 AM |
If you want to nosey round a finished car, you are welcome to pop over. Don't think you will be that far away?
Stuart Walker
| posted on 2/5/19 at 10:20 AM |
Thanks that would be great! I work in Chesterfield and Derby a lot so definitely not far away.
40inches
| posted on 2/5/19 at 10:33 AM |
I'm retired so in most of the time, U2U when you want to come over.
I'm 3 miles from J30/ 2 miles south of Crystal Peaks.
Angel Acevedo
| posted on 2/5/19 at 04:19 PM |
I reckon the strap would weight a lot less than the lower fixings.
But it will be your body strapped to those, so if you feel safer with your method, I´m in no position to argue against it.
Stuart Walker
| posted on 3/5/19 at 10:18 AM |
Fair point on both counts
Thanks 40inches, once I'm fully immersed in the build again I would love to come out and have a look at yours one day - thanks, I'll be in
touch.
Mr Whippy
| posted on 3/5/19 at 11:14 AM |
I always keep this in mind when doing belt fittings -
In a 30mph collision, an unbuckled backseat passenger will hit the front seats with a force of around 30 times their body weight, which could equal
the weight of a small elephant.
The forces involved in crashes are huge. I had a 30mph head on crash once and had a perfect bruise of the seatbelt right across my chest. Worked with
a guy who ran into the side of a lorry at 70mph and his belt actually broke and collapsed shorty after from a punctured lung. I lift engines out using
seatbelts...
Stuart Walker
| posted on 3/5/19 at 12:55 PM |
Thanks Mr Whippy, certainly a job to take time over and get right. Cheers
907
| posted on 5/5/19 at 06:29 AM |
Hi all,
Any thoughts?
[img] seat
I welded a plate between my twin cross tubes that had bosses welded underneath. These were tapped through, plate and boss,
and stepped swivel washers made to fit the seat belt ends. (see photo)
Paul G
40inches
| posted on 5/5/19 at 06:56 PM |
Looked at the Westfield chassis at Stoneleigh today, the rear belt mounts are the same as MK, but without the
strengthening added, this is a type approved left hand drive chassis
Stuart Walker
| posted on 28/10/19 at 10:06 AM |
Finally done this weekend, and I did it properly in the end. Now to try to match the paint... Reckon I'll just repaint the roll bars, then
probably the whole chassis...
0106b8c
2a7ba812708083ecd0a7704ea93df4b4ad1 by Stuart Walker, on Flickr
Mr Whippy
| posted on 30/10/19 at 07:03 AM |
