shortie
| posted on 3/2/05 at 08:53 PM |
Rear inner panel
Just wondered if others have just riveted the rear inner panel or have used Sikaflex\sealer on it aswell??
ta,
Rich.
bob
| posted on 3/2/05 at 08:56 PM |
I used some sealer just in case of rattle,well you never know do you
flak monkey
| posted on 3/2/05 at 09:29 PM |
I would be tempted to use rivets + PU adhesive. On the other hand, why bother riveting if using PU?
Sera
http://www.motosera.com
shortie
| posted on 3/2/05 at 10:10 PM |
Just realized I left the lid off my Sikaflex, is there anything the same I can get locally (diy store) instead of ordering it from somewhere??
ta,
Rich.
Mark Allanson
| posted on 3/2/05 at 10:15 PM |
I used PU and rivets, a pass of PU on each edge of the ERW to make sure that no moisture could get between the ally and the steel (electrowhatsit
corosion)
flak monkey
| posted on 3/2/05 at 10:19 PM |
See if theres any local to you there,
http://www.cjdirectory.com/product-60154.html
Dont know if Focus/Hombase sell PU adhesives.
If you have any car bodyshops nearby they may have some.
Mark you are talking about Galvanic corrosion i believe. Metals that are far apart on the galvanic scale react due to an exchange of electrons between
the metals creating a small voltage, any water in there will create a 'chemical wet cell' promoting corrosion. Incidentally this
phenomenon is the reason why thermocouples work. But they dont have the corrosion problem.
[Edited on 3/2/05 by flak monkey]
Sera
Avoneer
| posted on 3/2/05 at 11:52 PM |
Dixon Hall sell it if you have one of them near you.
Pat...
