smart51
| posted on 24/3/05 at 11:03 AM |
4 point harness length
how long are 4 point harnesses' shoulder straps from the lap belt to the mounting plate. I know that there are short ones and long ones. Would
48" / 1.2 m be the ones to use for a seven or not?
smart51
| posted on 24/3/05 at 12:02 PM |
guesses would be good.
does 4ft / 48"/ 1.2 m sound like the right length or not? A quick answer is better than a pricise answer. Please?
smart51
| posted on 24/3/05 at 12:15 PM |
They were for sale on ebay. No-one replied so I bid in the last seconds of the auction and won. I hope they are the right size.
craig1410
| posted on 24/3/05 at 01:06 PM |
Sorry, only just saw this or would have replied sooner...
I'd say that 48" is quite long for each shoulder strap but you can always tuck the excess away somewhere. I'd caution you against
cutting it unless you can stitch the end back up in the appropriate manner (not easy...)
Better to be too long than too short....that's what I keep telling my Wife anyway
Craig.
James
| posted on 24/3/05 at 02:45 PM |
- Muhammad Ali
ned
| posted on 24/3/05 at 04:38 PM |
if they are too long you may be able to mount them lower down in the axle/dif/boot space. i'm not saying this is a good idea, but it has been
mentioned before when someone asked about using saloon type harnesses which are much longer.
Ned.
beware, I've got yellow skin
Marcus
| posted on 24/3/05 at 08:28 PM |
Cut 'em, sew 'em and melt the ends so they don't fray, or just tuck the excess in the boot!
Marcus
Marcus
Because kits are for girls!!
smart51
| posted on 24/3/05 at 08:48 PM |
just picked up the harnesses. The are a bit long but will adjust just fine. the tails will be a bit long but cutting and sewing will probably
work.
Another fine bargain from Ebay.
