Northy
| posted on 24/4/05 at 04:40 PM |
4 point mounts on roll bar?
Hi guys,
I'm about to weld a bar across my roll bar to mount my 4 point belts to tomorrow, but am unsure on how far apart the two top mountings should
be?
Does it depend on the seats, or is there a better way?
Picture might show what I mean better
Distance: D
Graham
| posted on 24/4/05 at 04:59 PM |
Not sure how far apart they should be , sorry to hijack thread but do the Sabelt top and lower fittings conform to S.V.A. regs without any covers? If
not anyone have any suggestions as to what to use as covers?
907
| posted on 24/4/05 at 05:28 PM |
Hi
I'v made my centres 120mm.
They fit nicely through the holes in my Cobra seats.
Hope this helps
Paul G
DarrenW
| posted on 25/4/05 at 08:49 AM |
Just a point for those who havent passed SVA yet. If you mount seatbelt anchors off the rear roll bar be very carefull how you mount the roll bar to
the chassis. Rivnuts are definitely not OK. If you drill through chassis and bolt it on you need the right strength bolts and a means for preventing
any square tubing on the chassis from scrushing. Im not sure about welding - i guess this is good but dont know if the welds have to be checked.
My mounts are welded directly to the chassis at correct height etc, Roll bar is therefore independant (read - decorative).
Darren.
Northy
| posted on 25/4/05 at 08:51 AM |
Any more input onthe distance between fixings? I'll be doing it later today.
Graham
DarrenW
| posted on 25/4/05 at 08:58 AM |
Iam almost sure the distance will depend on the seats used. If seats have slots the belts need to go throu and over shoulders without touching the
seat (that is the rule for my grp seats anyway). If belts touch seats then in crash the seats will take some load and you need to ensure they are
strong enough.
Will you be able to work out the best spacing? Sorry i cant help more than this.
Northy
| posted on 25/4/05 at 09:10 AM |
Hi have Intertrim seats without harnes holes and was told by them that people usually route the belts round them.
SVA is not a problem, passed that last year, but safety still is.
Here's some pics of the car last year.
Graham
Northy
| posted on 25/4/05 at 09:11 AM |
Another
Graham
Northy
AnotherImage deleted by owner
Graham
Ben_Copeland
| posted on 1/5/05 at 09:00 PM |
bit late, but....
The upper mounting point of a lap/diagonal belt must be at least 450mm above the seat reference point, and at least 140mm outboard from the centre
line of the seat
So in theory a 4 point should be 140mm either sie of centre. 280mm apart.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Rorty
| posted on 2/5/05 at 03:32 AM |
If using bolt-on ends on a 4 or 5 point harness, then I too place them 120mm apart for any seat with twin webbing slots.
Ben, I think you're mixing up normal lap/diagonal belts with 4 point harnesses. They'll be totally diferent to mount, as the top of the
diagonal will be well off to the side (usually attached to the B post of a saloon).
Cheers, Rorty.
