Author: Subject: alternater?
harvey115
posted on 30/5/05 at 09:46 PM Reply With Quote
alternater?
what alternater do i use in my MK indy im running a 2litre zetec with bike carbs but there is no room for the zetec alternater
big_wasa
posted on 30/5/05 at 10:04 PM Reply With Quote
Looks like I am doing a simlar setup to your self..I have spent the whole bank holiday doing my alternator ..see http://www.locostbuilders.co.uk/viewthread.php?tid=26868
The standard alternator is often used with diferant brackets.. see http://www.kitcar.hu/jontarry/jontarry.htm
regards warren
DarrenW
posted on 31/5/05 at 08:03 AM Reply With Quote
I dont know if this will help you but i had to fit a Micra alternator on a custom bottom bracket for my pinto install.
Bottom custom bracket uses the two horizontal holes in the block that the std cast bracket usually bolts to. Above these are two smaller vertical tapped holes - a simple L bracket was fitted here so the the std sierra alternator adjustable bracket could bolt in place to get the belt tension. I need a 900mm belt.
ditchlewis
posted on 31/5/05 at 02:38 PM Reply With Quote
Like Darren W i have just fitted a alternator to my MK Indy which is powered by a Pinto. I tried all types of brackets (westfield, Tiger, L shaped 5mm bar). then I asked MK.
they told me to drill out the hole on the water pump and use this as the pivot point and use steel tube as a spacer. i used a 838mm belt and i have plenty of room now and also nice and far from the exaust.
The moral of the story is if in doubt ask kit supplier they are bound to be nice guys and very helpful and they must know someone who has done it before.
best of luck, the bleeding obvious is always staring you in the face.
ned
posted on 31/5/05 at 02:42 PM Reply With Quote
small nippon denso jobbie off a suzuki swift, daihatsu charade, suzuki vitara/sj410 etc is a nice small unit. believe Siert on here has used one on a zetec.
Ned.
ps try http://home.tiscali.nl/~svos/alternator.html
[Edited on 31/5/05 by ned]
beware, I've got yellow skin
