Author: Subject: Steering wheel, leather or suede?
James
posted on 12/7/05 at 12:18 PM Reply With Quote
I'm just thinking about ordering an OMP steering wheel from Rally Design.
I'd prefer the suede wheel over the leather but I'm concerned it'll get wrecked by rain etc. is this the case? Does everyone else use leather steering wheels?
Also, is it the leather with the cool yellow stripe at the top of the wheel or the suede or both?
Thanks,
James
[Edited on 12/7/05 by James]
posted on 12/7/05 at 12:24 PM Reply With Quote
I had a suede-covered wheel (jonbeedle is now the proud owner) and I had no real problems with it. Sometimes it got marked, but a quick attack with a suede shoe brush soon fixed it.
I've got a plain leather one now (only 'cos the spokes are nice shiny aluminium!) and it's no different in use. Mind you, I usually drive using light bike gloves.
Wadders
posted on 12/7/05 at 12:26 PM Reply With Quote
mines been soaked loads of times, with no ill effects.
bob
posted on 12/7/05 at 02:17 PM Reply With Quote
James
Ordering fancy steering wheels eh!!
You must be at the finishing post then,have you booked your SVA
James
posted on 12/7/05 at 02:35 PM Reply With Quote
More like at the stage of realising I need to buy different flexis for the front and I might aswell save as much on postage as possible!
James
ned
posted on 12/7/05 at 02:47 PM Reply With Quote
if you're trying to save money you could always call in some of your debtors
Ned.
beware, I've got yellow skin
bob
posted on 12/7/05 at 02:49 PM Reply With Quote
Might as well get your flexis from think auto and collect,M3 - A316 to twickenham/Isleworth
ned
posted on 12/7/05 at 02:52 PM Reply With Quote
if you're going that way james i think i have a list of bits somewhere i need
bob
posted on 12/7/05 at 03:00 PM Reply With Quote
There you are james,petrol payed
I'm going next month for my aero fuel filler,i'm fed up with the boot entry
Dale
posted on 12/7/05 at 03:47 PM Reply With Quote
On steering wheels, when you measure a steering wheel diameter do they use the outside diameter, the middle of the wheel rim or the inside of the wheel rim. I am using a mgb column but the wheel has an outside diameter of almost 16 inches and makes for a tight fit. Also anyon know what removable steering wheel hub can be used on a mgn column?
sorry for the hijack,
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
James
posted on 12/7/05 at 03:59 PM Reply With Quote
Bob, Ned,
You lot always make it so complicated!
Think I'll double check in case I don't need the lines:
http://www.locostbuilders.co.uk/viewthread.php?tid=28667
James
P.S. Thanks for the reminder Ned, I'll be in the garage tonight so will have a look for the receipt.
bob
posted on 12/7/05 at 05:09 PM Reply With Quote
Complicated!!!!!
We are here to guide you
I have no lock nuts on the flexi's into the caliper,SVA was fine so save yer money for something you need
