blockhead_rich
posted on 29/7/05 at 07:50 PM |
Central mirror recommendations
Hi folks
Can any one recommend a rear view mirror that I could fit to my scuttle and which is SVA compliant? Must look good and I would prefer either a
chrome or black / carbon finish.
Be handy to know who the best / cheapest sources are too!
Goes without saying that a pic' is worth a 1000 words!
Thanks in advance.
Rich
posted on 29/7/05 at 09:59 PM |
I made my own...
Take a typical commercial mirror (e.g. Sierra) and cut it on the stem, leaving a short peg. Make a base plate with all the right edges, drill a hole,
insert a piece of ali rod. make a 90 degree bend near the top, and drill a hole just big enough for the mirror's peg. Glue the whole thing
together with epoxy or Loctite 601.
You have a SVA-compliant mirror!
I can take pictures if you really want...
posted on 30/7/05 at 10:29 AM |
David,
Can you post a pic as I'm planning something similar with my Sierra mirror - always useful to see how someone else has done it
Nick
lenny
posted on 30/7/05 at 02:02 PM |
S/Steel thin pipe12mm bend 90%and cut to the hight you req , tig to S/steel plate glue "ball end " and that is it . made 2 one long other
short with same hole position in plate ,will try the long for SVA Lenny
![](/galpreviews/a241007-mirrors.JPG) ![Rescued attachment mirrors.JPG](/gallery/a241007-mirrors.JPG) Rescued attachment mirrors.JPG
posted on 30/7/05 at 08:37 PM |
Mine looks very similar to Lenny's example.
The only difference is that I made the joins to a faily close fit, and glued it together with Loctite 601 - a seriously strong adhesive.
![](/galpreviews/a241136-dscf0006.jpg) ![Rescued attachment dscf0006.jpg](/gallery/a241136-dscf0006.jpg) Rescued attachment dscf0006.jpg
And another...
![](/galpreviews/a241137-dscf0007.jpg) ![Rescued attachment dscf0007.jpg](/gallery/a241137-dscf0007.jpg) Rescued attachment dscf0007.jpg
posted on 30/7/05 at 08:38 PM |
and another...
![](/galpreviews/a241138-dscf0008.jpg) ![Rescued attachment dscf0008.jpg](/gallery/a241138-dscf0008.jpg) Rescued attachment dscf0008.jpg
Mave
posted on 1/8/05 at 05:57 PM |
How about the 20 pounds RaceTech kitcar centre mirror from Demon Tweeks? It looks wel made.
johnjulie
posted on 16/8/05 at 06:43 PM |
Have a look at:
www.holden.co.uk
Cheers John
JFDI
"Just F*****G Do It"
Slater
posted on 28/5/08 at 08:25 AM |
Very good ideas here, I will do something similar myself.
