DarrenW
posted on 31/8/05 at 02:24 PM |
The wonders of acetone
Just thought id share this with you.
If you use bond and seal and find some of its gets onto aesthetic areas i have found that acetone cleans it off. Take care to test the acetone on a
hidden area in case it will affect the gel coat etc. (I bought acetone in small bottles for a few penniew from my local chemists).
Did you know that acetone can also be used to bond ABS plastic. Either use neat and apply with small brush to both sides - wait till tacky and push
together. Shaving some abs and mixing with acetone in the bottle can also make abs filler / glue (takes a couple of days to disolve fully) - handy to
know if you want to join to bits at right angles (ie transmission tunnel or boot area).
posted on 31/8/05 at 03:42 PM |
Please read the following Data Sheet too...
ACETONE DATASHEET
chrisg
posted on 31/8/05 at 03:52 PM |
Nice drink - bit of a tangy after taste.
Chris
Disclaimer: the previous statement provides what we like to call a"joke" please do not drink acetone because I told you to. If you are
tempted to drink acetone, please ask the nurse to bring you your blue tablets
[Edited on 31/8/05 by chrisg]
Triton
posted on 31/8/05 at 03:59 PM |
groovy on cuts.....but will attack gel coat if you pour the stuff on so be careful ![](/images//smilies/bigsmile.gif)
DarrenW
posted on 31/8/05 at 04:00 PM |
Acetone also give a lovely colour when used to try and start your engine when pissed!!!! I cant recommend this tho as it could do alsorts of
damage!!!!!
The exhausts gasses also smelled very strange!
Triton
posted on 31/8/05 at 04:02 PM |
Started an X7 Suzuki years ago using a good squirt of wd40 into each carbie.....wow did it scream and never touched the throttle either........engine
went pop a few days later tho![](/images//smilies/bigsmile.gif)
splitrivet
posted on 31/8/05 at 04:28 PM |
You were a bit late with that disclaimer Chris drank a pint of the stuff and now find my arse welded to a pvc typists chair, please send me your
address so that my solicitor can send the court papers.
Bob
PS.
Did find it had a tangy taste but thought that was the cheap tonic water.
[Edited on 31/8/05 by splitrivet]
Fred W B
posted on 31/8/05 at 06:27 PM |
I use acetone a lot to clean things. It comes in a handy spray can labelled "Carb Cleaner"
Fred WB
chrisg
posted on 31/8/05 at 06:44 PM |
your address so that my solicitor can send the court papers.
Bob
PS.
you should find that handy for scooting round the Garage Bob!
You could sue me but I'm skint, I could do the elephant impression these days, it's all gone on petrol!!
Chris
Ps say hello to mrs Bob for me.
