kevano
posted on 18/10/05 at 05:17 PM |
blade 919 standard exhaust mk indy
after getting thrown off the track at donnington at the weekend for being too noisey, i was wondering if a standard can would make it quiet enough and
if it would fit onto my mk exhaust system? any ideas comments etc... cheers kev
Jon Ison
posted on 18/10/05 at 05:31 PM |
Q1..yes.
Q2..no, unless you weld a flange onto your exhaust too suit the 3 bolt fixing on the std can.......
andrew.carwithen
posted on 18/10/05 at 05:53 PM |
Yamaha R1 standard cans are reputed to be quiet.
In fact, I,ve just bought one which has been adapted for use on a BEC (see pic.)
As you can see, it has had a bent exit pipe added to end of can and it has a 'slip-on' inlet pipe, dia approx 52mm which should fit my MK
manifold
I dunno if this is the same dia. as the standard Yam link pipe though!
I also can't tell you how quiet it is, as I'm still some way off from starting the engine for the first time!
HTH,
Andy.
![](/galpreviews/a270371-AB end can 1 .jpg) ![Rescued attachment AB end can 1 .jpg](/gallery/a270371-AB end can 1 .jpg) Rescued attachment AB end can 1 .jpg
kevano
posted on 18/10/05 at 06:13 PM |
jon would it be ok if i got some sort of reducer and welded it onto the standard can, as i woul like to put my noisey one back on when not doing
trackdays?
kevano
posted on 18/10/05 at 06:14 PM |
how much did you pay for that andrew
andrew.carwithen
posted on 18/10/05 at 07:14 PM |
I paid £40 for it (seems to be about the going rate for a s/h R1 end can on ebay - 'though I bought this off Andy Bates at AB Performance.)
Do a search on ebay under 'end can' and they'll be plenty on there! (Obviously steer clear of any described as a 'race'
can or 'not for road use'!)
Andy.
Winston Todge
posted on 18/10/05 at 07:31 PM |
Have a squizz at this thread...
http://www.locostbuilders.co.uk/viewthread.php?tid=32407
The R1 can can be picked up very cheaply off ebay. And definitely nice and quiet, apparently.
Richard Miles and his website has some good info on the can... As seen in that last thread.
Chris.
posted on 19/10/05 at 01:11 AM |
Some cans come supplied with slipper connections on which may be suitable as a direct exchange depends on the bike really whether it is slipper or
bolt on. Some fireblade's are slipper.
IIRC the MK system is 2" before the can... some bikes are larger than that - so choose wisely and research before buying. Don't get a race
can as most are too loud and you won't get on't track.
You can always buy/make/steal/borrow a reducer/muffler to surpress noise but these sap power!
ChrisGamlin
posted on 19/10/05 at 08:00 AM |
Ive got a stock R1 can on my car, its certainly a quieter can than the ST repackable silencer I originally had on the car, but I still dont think it
will quieten it sufficiently for somewhere like Donington or Goodwood, I reckon its in the region of 100/102db as tested by most circuits.
Kev, you also need to bear in mind that you probably got thrown off for drive-by noise at Donington, and in a lot of cases the main creator of that
noise is not from the exhaust, but the induction roar generated when on full chat so putting on a quiet exhaust wont necessarily solve the issue. If
you currently run an open sausage air filter, it would be highly advisable to look at running the stock airbox if it will fit, or getting a custom
airbox made up if space is a problem.
Chris
kevano
posted on 19/10/05 at 05:42 PM |
thanks chris but i'm running a standard airbox,i've bid on a standard can on ebay so should be able to weld something up.
welderman
posted on 19/10/05 at 07:34 PM |
If you give me the size of your tube, ie on Blade can then i might be able to make you a swaged jointing piece which you can weld to the std Blade
can. Think yours is a standard MK one like mine so got the size of that already.
Does that make sense
[Edited on 19/10/05 by welderman]
Thank's, Joe
I don't stalk people
kevano
posted on 21/10/05 at 06:38 PM |
that'd be great but i've got a standard R1 can, i think this should be ok i'll give you the dimensions prob monday or tues, have you
got paypal. many thanks kev
