kango
| posted on 21/10/05 at 06:39 PM |
Weather profing Tunnel
Any good ideas of weather proofing the tunnel. Closing up the holes around the handbrake lever and gearlever.
I have a split welde in steel floor.
big_wasa
| posted on 21/10/05 at 06:46 PM |
eer no idea m8 other than the usuall sealer...
Still would like to know how you bent the square top tube on the back of your chassis tho please...
cheers warren
kango
| posted on 21/10/05 at 06:55 PM |
Cut a circle to the set outer diameter. Cut it into four and welder a 25 mm stip indetween two of the quoters, inside and outside. Will put the pics
in my archive tomorrow. It is on my other computer.
Would like to weather proof in such a manner that when I remove the pot of the tunnel I don,t have to reseal everything.
| posted on 21/10/05 at 10:59 PM |
I wouldn't bother as water spray etc will get into tunnel from under engine.
We put a small baffle in to deflect water away from the opening for the gear selector.
