DavidM
posted on 27/10/05 at 12:03 PM |
Carpets
Should I cut my carpet around my seat runners or would it be ok to bolt the seat runners through the carpet to the floor?
Any opinions would be appreciated.
[Edited on 27/10/05 by DavidM]
Proportion is Everything
wicket
posted on 27/10/05 at 12:05 PM |
Definitely cut round the seat runners, bolt metal to metal to get proper secure fixing.
romer
posted on 27/10/05 at 02:25 PM |
I would bolt through the carpet and leave for a week or so if you have the time. then remove the runners and it will be easier to see crushed carpet
to cut around and make a neat job. Then rebolt direct mounting points for strength.
IMHO for what it's worth.
Romer
posted on 27/10/05 at 05:41 PM |
We bolted ours down through the carpet. No problems to report so far
posted on 27/10/05 at 07:01 PM |
Why do you want carpet ? Especially under the seats where you won't see it and it will get wet eventually and go mouldy.
DavidM
posted on 28/10/05 at 12:20 AM |
So it's nice and soft and fluffy.
Looks like I'll be bolting through the carpet, then If I have any problems using the marks to cut around the runners, bolting directly to the
floor and then when the carpet gets damp and curls up at the edges taking it out.
Still it'll give me something to do after the car's finished.
Thanks for the thoughts fellas.
Hellfire, did you have any problems with bolting through at SVA?
Hornet
posted on 28/10/05 at 07:08 AM |
My penniesworth.....
I bolted straight through carpets.. no problems at all.
However, you WILL definately get caught in the rain and this area WILL retain a lot of water.
Wish I could remove carpet easily as its a pain to dry out.
zetec
posted on 28/10/05 at 06:11 PM |
I cut around runners and fit down with velcro, then if (when!) it gets wet take it out and dry. Also if it gets tatty saves taking the seats out to
change it.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Kitlooney1000
posted on 5/11/05 at 11:58 AM |
I'm glad i didnt put carpet in mine, especially when the rear seal on the gear box went and oil leaked through from the transmission tunnel into
the foot wells.
Doesnt matter what Sh*t life throws at you, there is always some other poor bugger worse off!!!!!
DarrenW
posted on 6/11/05 at 10:39 PM |
My twopenneth - defo no carpets. Ive got 5 bar ali chequerplate floor whickh looks great and wont go smelly and mouldy.
wilkingj
posted on 6/11/05 at 10:56 PM |
Use Kitchen carpet aka Flotex or simmilar Bathroom carpet.. Fluffy and WATERPROOF.
Or none... ie Chequerplate.. only get electrolytic white rust from the electolytic action of dissimmilar metals.
Best Regards
Geoff
http://www.v8viento.co.uk
