Author: Subject: Clutch master cylinder bore?
Matthew_1
posted on 4/12/05 at 07:51 PM Reply With Quote
has anyone used the burton power clutch master cylinder for a type-9? Any idea what's best bore master cylinder to use ?
NS Dev
posted on 5/12/05 at 10:55 AM Reply With Quote
not used the burton one, but I'd guess it's around 7/8", in which case you will want 0.75" master cyl. 0.75" is normally seems to work with most hydraulic clutch setups.
