RazMan
| posted on 16/1/06 at 10:10 PM |
Gimme some bloomin seats!!
I'm back on the seat trail again having decided that my Lotus Elise seats are a little too 'sit up and beg'. My GT has a low roof
and I need the headroom. Width is not a problem (except the width of my backside )
I need a pair of seats which:
Are quite laid back, almost like a karting seat.
Extra wide for a 6' 2", 17 stone salad dodger
Ideally silver or grey fibreglass with smooth finish
If not already trimmed they need to be trimmable - even rubber pads are acceptable
I know that there will be seat manufacturers reading this so come on guys, what have you got for me?
Raz
Triton
| posted on 16/1/06 at 10:13 PM |
Can do these in grey gel coat but better still why not have the entire face in carbon fibre
www.tritonraceseats.com
www.hairyhedgehog.com
Triton
| posted on 16/1/06 at 10:14 PM |
Can tissue the backs if you are concerned about the matt finish (done anyway on carbon version)
Triton
| posted on 16/1/06 at 10:17 PM |
Inserts available that need to be trimmed to suit
welderman
| posted on 16/1/06 at 10:23 PM |
Still pondering on those seats for the Mini. What are the sizes and i will measure the Cobras i have at work to compare.
Thank's, Joe
I don't stalk people
Triton
| posted on 16/1/06 at 10:35 PM |
430mm wide at widest point and 875mm to top of seat from floor.......fit 6ft 6" 17st easy and comfy to boot.
Humbug
| posted on 16/1/06 at 10:39 PM |
Welderman - I should think your avatar must have really bad nipple rash by now!
Triton
| posted on 16/1/06 at 10:45 PM |
smutty bloke has some ointment for that nasty rash
RazMan
| posted on 16/1/06 at 10:46 PM |
They certainly look the part Triton but are they angled back more than the average seat?(this factor is vital)
I am sure that the carbon fibre looks great but it isn't the look I want - silver grey gelcoat would be fine and weight is not a concern.
welderman - your avatar is hypnotising me again
Raz
Triton
| posted on 16/1/06 at 10:59 PM |
Razman....I can do some magic when making the seats to create more angle of dangle....what angle are you after?
jonno
| posted on 16/1/06 at 11:00 PM |
Are Vx220 or mx5 seats adjustable, just a thought !
RazMan
| posted on 16/1/06 at 11:07 PM |
They are too thick in the base IIRC. I'm even thinking of trying thinner underpants to get more headroom
Triton, the dangle angle wrangle sounds promising - have you got a drawing of your seat so that I can compare with other seats. I probably need an
extra 5-10 degrees IMO
Here's a very laid back one - a bit too far though I think.
[Edited on 16-1-06 by RazMan]
Raz
Triton
| posted on 16/1/06 at 11:13 PM |
Drawing! blimey what's one of those!!
I have an outline i borrowed from somewhere that i can add the dimensions to if that helps?
Or you could mount the seat at an angle using side plates as i can bond the inserts into the sides
RazMan
| posted on 16/1/06 at 11:25 PM |
The trouble is when you lay the seat back, the front rises and pushes your thighs upwards.
If you could post a pic of the side view it would help me to visualise the angle.
Have you got anyone in my neck of the woods with one of your seats?
Here's a fairly standard jobby
Raz
RazMan
| posted on 16/1/06 at 11:26 PM |
and from the side
Raz
Triton
| posted on 16/1/06 at 11:32 PM |
Don't think I have sent any to Essex.
I will have to fill in the dimensions tomorrow as don't have a seat here with me.
welderman
| posted on 16/1/06 at 11:36 PM |
Thanks for the seat size. I'm off now to lube up those nipples.
Thank's, Joe
RazMan
| posted on 16/1/06 at 11:42 PM |
Here's a Cobra standard bucket - these are very upright and a bit of a tight squeeze width wise. My missus got her butt stuck in one in Halfords
once
Raz
Fred W B
| posted on 17/1/06 at 08:38 AM |
Raz man - have you tried wedging a plank of wood into the car as a dummy seat behind your back at the angle you want to lean back to. Then just
measure the angle by using an bubble degree gauge. You can then measure the angle of other seats. I sit with the back at 30 degrees from vertical
FWIW. Most standard touring car seats seem to be only 10 deg from vertical. It doesn't sound like much, but try it. You might imagine you need
45 degrees, but that would be extreme
Fred WB
[Edited on 17/1/06 by Fred W B]
Triton
| posted on 17/1/06 at 08:43 AM |
The witch's hat seat is same angle as Locost rear bulkhead @17degrees the others are nearer 25 degrees.
fesycresy
| posted on 17/1/06 at 08:50 AM |
Triton,
What's tissue on the backs of the seats ?
Did you get my email regarding the dash boards ?
Cheers.
tadltd
| posted on 17/1/06 at 09:32 AM |
Our seats have the angle your looking for. Depending on which way you measure them, it's a 35 degree back rest angle from vertical (55 from
horizontal).
We used the technique Fred mentioned when designing our seats because we couldn't find one on the market that would suit the LMP, the closest we
could get was the kart seat shown in your picture. So we used that as a 'guide' and added leg support. There's a pic of them in this
forum area and in my photo archive...
Here ya go:
  Turner seat
[Edited on 17/1/06 by tadltd]
Best Regards,
Steve.
www.turnerautosport.com
RazMan
| posted on 17/1/06 at 11:07 AM |
Steve, The LMP looks as though it is very similar to my GT, at least in driving position. I think I can get away with 25-35 degrees which means your
seat is probably the closest so far.
I U2U you shortly mate
Fred, thanks for the tip regarding angles - although I havent got a bubble thingy I am pretty sure that your seat angle would be about right too. It
gives me a good guide regarding what to look for
Raz
Fred W B
| posted on 17/1/06 at 05:10 PM |
Razman - Just rechecked my seat angle, actually is 32-33 degrees
Fred WB
Triton
| posted on 17/1/06 at 06:59 PM |
Surface tissue provides a better visual finish to the rear of the seat..And the angle is 30 degrees.
GRP seats weigh 4.5kgs
Carbon 4.2kgs
No need for extra mounting frames as built in mounting points
