joolsmi16
| posted on 28/1/06 at 11:13 PM |
small seat
Hi all, just tried to fit into these bucket seat and failed! Looking now to remove some of the fibreglass from both side walls to allow some
flexibility so I can fit?
The yellow section is what I am thinking of removing.
Can anyone think of any issues or another method??
Triton
| posted on 28/1/06 at 11:20 PM |
Cut it down to where you want then if there is room bond something along the edge to add stiffness....or add more layers of 'glass
Other method is to buy some seats you fit into but as you have those mod them
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
k33ts
| posted on 29/1/06 at 12:08 AM |
you could try heating them up with something giving outward pressure .
depends alot on thickness of seat and how much you need togo
not to hot though else they bubble.
Triton
| posted on 29/1/06 at 10:06 PM |
Don't use direct heat...poke a stick in there to spread it out if it does owt that is...then make a box and aim a convector heater in
there...leave it over night.....cheaper to cut it though
