Author: Subject: Ford sierra colum shroud.
ditchlewis
posted on 4/2/06 at 01:37 PM Reply With Quote
Does any one know where i can get a column shroud from. i have had broken the plastic lugs on the one i have.
Ditch
RichieC
posted on 4/2/06 at 01:40 PM Reply With Quote
Still available from Ford for about £20 for the top and bottom
big_wasa
posted on 4/2/06 at 02:08 PM Reply With Quote
Top or bottom ?
Ive got both but the top one along with the hazard is broken so was going to bin it.
Any use ?
ditchlewis
posted on 4/2/06 at 06:20 PM Reply With Quote
many thanks big wazza, but like you it is the top one thats broken, guess i will have to try and fix it with plastic glue and plastic card.
ditch
indykid
posted on 4/2/06 at 06:49 PM Reply With Quote
i think the top bit was about £8 last time i asked. there were some more recent prices posted a bit back.
might be worth a search
tom
tom windmill
posted on 4/2/06 at 06:57 PM Reply With Quote
payed 6 quid for a new one from ebay.
hth Tom
posted on 4/2/06 at 07:37 PM Reply With Quote
Mine split round the hole on top so I just dropped a washer in before I put the screw back and it holds o.k.
indykid
posted on 4/2/06 at 08:09 PM Reply With Quote
i stuck my washer in, but it achieves the same thing. i got fed up of fishing the washer out from the bottom cowl so did it more out of annoyance than anything else.
the first one i had, had cracked off on the top of the bit that drops down for the screw, and was held on with blutack, the other had snapped out where the screw bears on. i still couldn't find a 'perfect' one in all the scrappers i looked in.
for £6, i'd save the hassle and petrol
tom
ditchlewis
posted on 6/2/06 at 12:00 PM Reply With Quote
Many thanks lads.
ditch
