Author: Subject: SPA MD-16-B Oil temp pressure sensor spec?
hobbsy
posted on 15/2/06 at 01:42 PM Reply With Quote
I have one of these in my fireblade engine and wondered if anyone knows the specs of it and whether it would work with my ETB Digidash 2 Pro???
It was left over from the previous owners SPA digital dash and its in pretty tight...
A quick search hasn't turned up any info...
DarrenW
posted on 16/2/06 at 10:06 AM Reply With Quote
If you read the ETB blurb they recommend using the ETB sender only that is supplied with the kit. For bike engines i recall reading that this has to be remote muonted and not directly in the block. Have a read of the instruction and use what they recommend or you could run into warranty problems.
