ditchlewis
posted on 20/2/06 at 09:28 AM |
How do i make my dash board safe???
I have made a dash board out of 6mm external ply covered with a layer of foam and then vinyl sheeting. I thought that the foam padding would be enough
for sva, David J has very kindly had a look at the car yesterday and informed me that the padding had to be hard padding to pass, or it should have a
19mm radius.
would the dash board pass if i put herring bone edge piping (the type used for the external wings) along the bottom of the panel?
see attached picture
Ditch![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
graememk
posted on 20/2/06 at 09:32 AM |
is it a magic eye photo ?![](/images//smilies/bigsmile.gif)
ditchlewis
posted on 20/2/06 at 09:34 AM |
here is the picture
![](/galpreviews/a328070-dashboard.jpg) ![Rescued attachment dashboard.jpg](/gallery/a328070-dashboard.jpg) Rescued attachment dashboard.jpg
graememk
posted on 20/2/06 at 09:36 AM |
if its wood cant you put some more wood or mdf behind and make it rounded ? maybe with a router or something ?
ditchlewis
posted on 20/2/06 at 09:54 AM |
do you mean like this?
![](/galpreviews/a328083-dashboard 1.jpg) ![Rescued attachment dashboard 1.jpg](/gallery/a328083-dashboard 1.jpg) Rescued attachment dashboard 1.jpg
dave1888
posted on 20/2/06 at 09:58 AM |
I would go with a 19mm radius edge with padding and vinyl .
paulf
That might not be acceptable to the inspector, i used 25mm dia tube and covered it in foam and then vinyl . if its hard not padded ,it must be the
19mm radius ie 38mm dia which is a bit excessive.Maybe you could use a broom handle with a slot routed in it for the bottom of the dash to fit in and
then cover with foam and vinyl as per existing dash.
Paul.
shortie
You could do exactly what I did.
I bought some 19mm coolant hose and then split it along it's length.
Then I pushed it onto the bottom of the dash and secured it behind with staples, can't be seen from the front and after SVA the staples just
happen to fall out!!
HTH,
Rich.
ditchlewis
posted on 20/2/06 at 09:59 AM |
Or like this?
![](/galpreviews/a328088-dashboard 2.jpg) ![Rescued attachment dashboard 2.jpg](/gallery/a328088-dashboard 2.jpg) Rescued attachment dashboard 2.jpg
graememk
posted on 20/2/06 at 10:01 AM |
mine is like your 2nd photo
ditchlewis
posted on 20/2/06 at 10:02 AM |
Thanks Shortie i have some excess cooling pipe at home about 19mm i think thats what i will do.
regards
posted on 20/2/06 at 10:13 AM |
Don't forget that the critical dimension is 19mm RADIUS, not diameter - you'll need 38mm dia pipe (roughly 1.5" )
cheers,
[Edited on 20/2/06 by David Jenkins]
paulf
posted on 20/2/06 at 10:20 AM |
The radius is only critical if it is a hard surface, if padded it just needs to be curved to a sensible radius.
Paul
cheers,
posted on 20/2/06 at 10:27 AM |
It does have to be padded quite firmly, and the tester must not be able to feel the hard bit underneath the padding.
If it's properly padded, the radius is 5mm.
DJ
shortie
posted on 20/2/06 at 11:09 AM |
Coolant pipe will be fine, he didn't even question mine, 19mm as already mentioned is for hard surface, the pipe is rubber and therfore fine.
Rich.
