Author: Subject: hole saw sizes
posted on 26/2/06 at 03:07 PM Reply With Quote
hole saw sizes
Are hole saws readily available in 54 and 82mm diameters?
I'm fitting ETB 80 52 and 80mm gauges to my dash.
Nick
omega 24 v6
posted on 26/2/06 at 03:20 PM Reply With Quote
You can see whats available here mate.
http://www.starrett.co.uk/downloads/saws/hole_saws/starrett_general_hole_saws_specs.pdf
Nick Skidmore
posted on 26/2/06 at 03:36 PM Reply With Quote
Use the 52mm and 80mm hole saws that are available.
They are sized to give clearance over their nominal sizes so your gauges will fit through the holes you drill with a 52mm and a 80mm hole saws.
Aboardman
posted on 26/2/06 at 03:52 PM Reply With Quote
you need one of these
http://cgi.ebay.co.uk/ADJUSTABLE-HOLE-CUTTER-BIT-LIKE-HOLE-SAW_W0QQitemZ4442172325QQcategoryZ632QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
omega0684
posted on 26/2/06 at 04:13 PM Reply With Quote
dont you need to cut the holes a little bigger to allow for th evinyl or leather that needs to go through?
Alex
posted on 26/2/06 at 04:54 PM Reply With Quote
Hole saws always wobble and cut a slightly bigger hole than the nominal size.
posted on 26/2/06 at 07:44 PM Reply With Quote
cheers guys - checked what sizes my dad had at work and found a 50, 51 & 52 so will try all 3 and see which gives the best fit. Will have to buy a larger one though.
