BKLOCO
| posted on 21/3/06 at 08:21 PM |
Steering wheel boss ID.
This is a photo of a steering wheel I would like to use post SVA.
It is quite an old wheel with imperial dimensions.
What I would like to know is if any of the modern wheel Bosses will either fit or are of suitable size to be modified.
The sizes of the wheel are:
Centre hole = 4 1/2"
Bolt PCD = 5"
6 bolt holes.
  Steering wheel
donut
| posted on 21/3/06 at 08:22 PM |
Classic Mountney boss should fit that.
| posted on 21/3/06 at 08:46 PM |
Mine passed SVA with one of those fitted, just cover the centre up so you can't feel the studs.
Marcus
| posted on 21/3/06 at 09:23 PM |
Yup deffo Mountney wheel. Astrali bosses also fit (if you can find one) and are collapsible and SVA friendly.
Agree with Pete, cover fixings up with centre pad. (I used cut up manta centre)
Marcus
Marcus
Because kits are for girls!!
Gav
| posted on 21/3/06 at 09:45 PM |
Looks exactly the same as my new mountney wheel so would imagine a new mountney boss will be fine, however ill measure mine up tomorrow for you to
make sure their the same.
cidersurfer
| posted on 21/3/06 at 09:48 PM |
Mountney were helpful with a question I had about a boss recenly
http://www.mountneyltd.com/contact.htm
shimming solid lifters is a job for a friend...
indykid
| posted on 21/3/06 at 11:14 PM |
you need the mountney classic boss, not the mountney 'm' range boss.
the m range boss is the little one to fit momo/sparco etc etc wheels.
hth
tom
