timwest167
posted on 5/4/06 at 03:37 PM |
My Interior
Thought I'd show the fruits of my hard work. May not be up to some peoples standards (and it's obvious where I got particular inspiration
from!) but I'm quite pleased with it
Tim
timwest167
More...
Tim
timwest167
posted on 5/4/06 at 03:38 PM |
And another...
Tim
CommanderAce
posted on 5/4/06 at 03:43 PM |
sweeeeeet!
Roads? Where we're going we don't need roads!
k33ts
posted on 5/4/06 at 03:44 PM |
is that another avon local'ish
looking good i like the paint scheme got a better picture.
is it a road goer yet
posted on 5/4/06 at 03:45 PM |
Looks nice... as long as Mr SVA likes it...
timwest167
posted on 5/4/06 at 03:48 PM |
Hoping to get it finished by the end of April, then on the road for the summer.
Is there anything in particular Mr SVA man might not like? I'm starting to get sleepless nights - won't be long till the nightmare
starts!
RazMan
posted on 5/4/06 at 05:51 PM |
Looking good!
You might have to put a different steering wheel on for SVA or fit a pad (all import Miata's come with these)
Just being picky - why are the main clocks off centre?
[Edited on 5-4-06 by RazMan]
Raz
soggy
posted on 5/4/06 at 10:41 PM |
cool someone else to play with rob
if at first u dont succeed use a bigger hammer!
Marcus
posted on 6/4/06 at 08:05 AM |
Is it an optical illusion, or is the steering wheel set quite high?
Took me ages to decide on position of mine, I sat for half an hour holding wheel to find most comfy position. Could be very tiring on a run.
Marcus
Marcus
Because kits are for girls!!
timwest167
posted on 6/4/06 at 09:59 AM |
Thanks for the positive comments...
Dials are offset so I can see both of them clearly. I know it doesn't look as good, but thought practicallity made more sense.
Steering wheel is unfortunatley high on all Avons. It's as low as possible without moving the bracket - havn't got a welder and
can't weld I think it also looks higher than it is as the scuttle is quite low on the Avon - It's the same hight as a mates Tiger CAT,
which doesn't look half as bad.
I've bought a pad for the wheel - it'll be glued on prior to SVA.
Tim
posted on 6/4/06 at 01:12 PM |
I owld see those are from Tiger.
The swteering wheel is well high!! So he must be a tall boy ... or the bulkhead is very low. I had to raise my staeering wheel up but not as high as
that!! (stil had room behind it for three 50 mm guages)
James
posted on 7/4/06 at 07:31 AM |
Looks really good Tim.
I particularly like the tunnel cover with the stitching and the way you've done gearstick gaiter. Nice one!
James
- Muhammad Ali
