RazMan
| posted on 12/6/06 at 01:06 PM |
Small steering wheels?
I'm having quite a job finding a small steering wheel other than the 'traditional' style 3 spokes. Ideally I need something under
300mm dia - any suggestions?
Raz
Agriv8
| posted on 12/6/06 at 01:17 PM |
razman is smaller wheel required for leg knee room.
as this works well in my setup
  V8Gauges
[Edited on 12/6/06 by Agriv8]
zxrlocost
| posted on 12/6/06 at 01:45 PM |
thats what Ive got great bit of kit
Marcus
| posted on 12/6/06 at 02:04 PM |
OMP do a good range of wheels at about 300mm dia. I'm going to buy a Trecento when funds allow.
Linky
Marcus
Because kits are for girls!!
gingerprince
| posted on 12/6/06 at 02:18 PM |
If you want small then you could get a Go Kart steering wheel. That's what mine has: -
Advantage is the wheels are nice and cheap, as is a removable boss.
RazMan
| posted on 12/6/06 at 02:22 PM |
You guessed my problem Agriv8 I've got a 330mm flat bottomed Momo which I hoped was going to give me enough room but now that I've
trimmed my seats the legroom has become a problem yet again.
I wonder if the smaller Momo would do it.
I found a Volanti 300mm which has an offset (similar effect to a flat bottom I suppose)
Ginger - where did you get your kart wheel?
[Edited on 12-6-06 by RazMan]
Raz
rpsmith
| posted on 12/6/06 at 02:24 PM |
Gingerprince, where did you get your steering wheel and boss from?
Rich
Agriv8
| posted on 12/6/06 at 03:05 PM |
I think mine is 300 ( ohh er ) will measure tonight if required
Must admit its a fine sterring wheel ( its the connection between that and the pedals thats the problem - ME !!! ).
Mine has a Quick relaease boss on ( this was to assist in getting in and Out ) but dont need to remove ( only do that for rain / security )
the MNr is very generous for leg room my legs are slightly bent ( 38 inside leg )
but grabbed a bit more by adjusting the column mount as far up the scutle as possible and makling sure that all the peddles were vertical at start of
travell helped.
what about a large spacer behing the wheel ( seems a shame to waste a nice steering wheel ) or hight adjustable column perhaps ?
Regards
Agriv8
RazMan
| posted on 12/6/06 at 03:49 PM |
Been there done that I'm afraid - adjustable Sierra column at its highest setting and a boss which spaces the wheel away from the dash (problem
is I cant easily reach the stalks now)
I just need that extra inch and all will be well (don't we all ) I suppose I could replace the boss with a 'deep dish' rally style
wheel like this - that might help.
Raz
muzchap
| posted on 12/6/06 at 05:09 PM |
I got the 300mm Trecento - arrived today!
Its awesome - perfect size and looks fantasic!!!
Cant wait to fit it - post something or other
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Liam
| posted on 12/6/06 at 05:16 PM |
You could try and get hold of a caterham wheel like I got. 260mm momo.
Liam
Fred W B
| posted on 12/6/06 at 05:45 PM |
More kart wheel stuff
Fred W B
Agriv8
| posted on 12/6/06 at 07:43 PM |
Razman,
Did not realise you were building somthing a little diferent good on yah.
Guessing honda v6 ? how are you finding the davis water pump ( are you running the thermostatic speed control ?) oh nice battery by the way both of
these are on my to do list when I save up some pennies
My OMP id width 330mm and the base of the flat is 130 mm from the center by the way.
regarding getting the wheel closer to you and away from your knees. I beleive the triangle part of the steering shaft can be pulled out of its outer
a little. the space the bracket with washers packers.
Think the cart wheel best option.
Regards
Agriv8
RazMan
| posted on 12/6/06 at 07:59 PM |
Yep, I decided to do things a little differently
I'm using a Duratec V6 in standard tune (ish) with some Nitrous Oxide to make thing a bit more interesting. I ditched the standard water pump
(they are prone to shattering I'm told ) and replaced it with the Davies Craig pump and controller. The pump runs although the engine
doesn't yet - but it will soon
I'll have a fiddle with the brackets and see if I can gain some more height but I am almost certain I now need a 300mm wheel - the flat bottomed
variety wouldn't make much difference to me as my knees are wide apart when I drive anyway and they touch the sides more than the bottom.
Raz
RichB
| posted on 13/6/06 at 11:41 AM |
My missus bought me a momo team wheel (280 mm). It looks and feel really nice but I haven't fitted it yet so I can't advise on the
clearance etc.
Rich
