Pdlewis
| posted on 23/8/06 at 06:16 PM |
Horn position
Hello,
I have just had to replace my indicator stalks because the hazzard switch had failed and the new stalks do not have a horn on the end.
So my question is, is it ok to put the horn button on the dash? as my MOT is due this week and dont want it failing on something so simple
Paul
Bladerunner
posted on 23/8/06 at 06:29 PM |
Get one of these flip switches that will fit within the Steering wheel radius and ther should not be any problems
stevebubs
| posted on 23/8/06 at 07:15 PM |
short answer is - yes, dash mounted is OK.
davrus
| posted on 23/8/06 at 10:05 PM |
No problem there at all sir .
Dusty
| posted on 23/8/06 at 10:06 PM |
If you are using sierra column switches better check the wires. They changed in 1987.
jollygreengiant
| posted on 24/8/06 at 02:24 AM |
Just needs a big readable label that SHOUTS at the tester HORN.
jonbeedle
| posted on 24/8/06 at 09:11 AM |
You can put a push button on the dash as I did, but you don't need a horn for SVA anyway, but you will need one for use on the road and for
subsequent MOTs.
"Everyone is entitled to an opinion however stupid!"
