the_fbi
posted on 15/10/06 at 06:37 PM |
Harness hole trim for GTS seats?
I need to place an order with Woolies ( http://www.woolies-trim.co.uk ) so which is the best edge trim to get for around the harness holes?
I presume the seat edges are OK uncovered?
ta
Chris
StevieB
posted on 15/10/06 at 06:56 PM |
Best to do the seat edges as well - you can always take it off later if it doesn't look good, but it'd be a pretty bone thing to fail SVA
on for the sake of a few quids worth of edging trim!
mark chandler
posted on 15/10/06 at 08:34 PM |
These are the wholesalers that supply woolies et al, they own the tooling.
Baines, tunbridge wells
Page 99 U shaped rubber with steel reinforcing (eps9's the stuff), comes in a few sizes all @ £1.11 per metre.
U shaped rubber
Also do ribbed floor mat etc, you will not find this stuff any cheaper !
Regards Mark
[Edited on 15/10/06 by mark chandler]
the_fbi
posted on 15/10/06 at 08:52 PM |
Excellent, thanks Mark ![](/images//smilies/smile.gif)
RazMan
posted on 15/10/06 at 09:37 PM |
Have a word with Cobra and they will supply the proper 2 part mouldings specially designed for harness holes.
Raz
the_fbi
posted on 15/10/06 at 09:44 PM |
GTS as in Darren as in GTS Tuning, not GTS as in Cobra GTS seats
Unless you're saying that Cobra somehow do one which fits the seats Darren sells?
RazMan
posted on 15/10/06 at 10:11 PM |
If you have a look at most seats they tend to use the same moulding - mine are Ultima seats and they fit. Not sure about your seats though
Raz
the_fbi
posted on 15/10/06 at 10:50 PM |
Most seats these days (apart from the Ultima ones it seems) appear to have trianglar('ish) shaped harness slots, never seen any with
"proper" plastic inserts in them. Even Caterham's version (Tillett) doesn't
Rubber edge trim is the way to go.
NS Dev
posted on 18/10/06 at 11:57 AM |
U shaped rubber
Regards Mark
I "might" be able to get hold of a lot of edge trim at VERY good price.
If there is enough interest, I work for an extrusion company now that make the rubber extrusions for 85% of the world automotive market, and I know we
have a lot of edge trim etc in stock.
If I can drum up a few thousand metres of demand we could possibly do a run and I can assure you the cost is a lot less than £1.00 a metre!!! ![](/images//smilies/bigsmile.gif)
