wilkingj
| posted on 25/10/06 at 04:38 PM |
Hidden Relays
Paul / 907
Where my Relays are hidden:
The plate is 90deg bent ally with nutserts put in it.
Then all covered up with a bit of Stainless left over from the new Cooker head vent, again just held in with nutserts. Nothing exciting really.
  Relay Plate behind Dash
  Passenger Footwell
Best Regards
Geoff
http://www.v8viento.co.uk
alfasudsprint
| posted on 25/10/06 at 06:32 PM |
for security?
907
| posted on 25/10/06 at 08:15 PM |
Unhidden Relays
Hi Geoff.
I prefer the "Cluttered Look"
If you think this is bad you ought to see my work bench.
Paul G
p.s.
When are you getting a piccy reducing program?
I had to pan across just to find a smiley
wilkingj
| posted on 25/10/06 at 09:45 PM |
quote: Originally posted by alfasudsprint
for security?
No.. Purely to protect them from kicking feet, and I had a bit of Kitchen Fan vent going spare.
Paul asked me where my relays etc were, as my under bonnet area is a bit bare.
Hmm.. Mind you it must have a security effect... didnt thiink of that at the time!
Best Regards
Geoff
PeterW
| posted on 26/10/06 at 08:49 AM |
quote: Originally posted by 907
Hi Geoff.
Paul G
p.s.
Paul
Is that a heater matrix in the bulkhead..?
I was considering doing something similar and using individually switched PC fans to power the vents etc They are good for up to 50cfm, cheap and
quiet !
Peter
907
| posted on 26/10/06 at 06:44 PM |
They are good for up to 50cfm, cheap and quiet !
Peter
Hi Peter
A real locost job this.
The heat exchanger from an old Tig welder thrown out at work.
A fan from a electric control cabinet, walk in jobbie,
and a vacuum cleaner hose, not fitted yet, will screw into the round holes in the back.
O, and some odd bits of scrap stainless, 0.5 thick, which is why it's spot welded. A bit thin for the Tig.
Cost..... Bu**er all.
Paul G
