Author: Subject: Recovering a Steering Wheel?
RazMan
posted on 25/10/06 at 10:27 PM Reply With Quote
This might be a silly question but is it feasable to retrim a steering wheel? I'm thinking about a change in colour and maybe making it more SVA friendly.
Raz
zetec7
posted on 25/10/06 at 10:39 PM Reply With Quote
I've done it a couple of times, with success, both times with leather. If you can find some soft, stretchy tanned leather (I bought an old used leather jacket at a second hand store, and cut out what I needed), just measure the circumference of the rim, add enough width for a slight fold-over on each side, and cut a piece long enough to go round the outside of the wheel. I stitched mine by hand (that takes a while), stretching it very taut. It shrunk over a couple of hours, and ended up tight as a drum - better than the original. On the second one, I even used a thin layer of foam inside to make it more padded. The leather smells nice, too!
RazMan
posted on 25/10/06 at 10:51 PM Reply With Quote
Cool I've got some Alcantara left over from my dash and it would look sooooo much nicer than plain old black.
Raz
RoadkillUK
posted on 26/10/06 at 01:22 AM Reply With Quote
[Edited on 26/10/06 by RoadkillUK]
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
zetec7
posted on 26/10/06 at 02:12 AM Reply With Quote
Does anybody else have trouble with RoadkillUK's link? I felt like I was in a loop...in a loop...in a loop....
http://www.freewebs.com/zetec7/
RazMan
posted on 26/10/06 at 06:07 AM Reply With Quote
Ooh look, a groundhog!
Raz
donut
posted on 26/10/06 at 08:08 AM Reply With Quote
You can use a horse sadle maker if you don't want to do it your self
posted on 26/10/06 at 09:34 AM Reply With Quote
I considered using self adhesive leather tape, the sort that you use on tennis/squash/badminton raquets but never got round to doing it so don't know how good it would be - locost would be to use towel wrap!
posted on 26/10/06 at 09:35 AM Reply With Quote
Hey Andy!
Hey Andy,
What are your plans for this?
Image deleted by owner
other then painting it to be one colour? someone on another forum is planning to fit a haybusa in the rear of a mini!
[Edited on 26/10/06 by 02GF74]
James
posted on 26/10/06 at 11:37 AM Reply With Quote
Originally posted by 02GF74
Hey Andy,
I think the general consensus of opinion is spend a fortune paying other people to do the work and then sell it at a loss 2 weeks later...
Sorry Donut, too easy!
James
jack trolley
posted on 26/10/06 at 04:24 PM Reply With Quote
Current issue of one of the classic mags. (Motorsport, I think?) has a feature on
Motolita, which shows how wheels are made: fairly low-tech. actually.
RoadkillUK
posted on 26/10/06 at 04:30 PM Reply With Quote
Sorry for the non-working link, post deleted
Roadkill - Lee
www.bradford7.co.uk
posted on 26/10/06 at 06:26 PM Reply With Quote
A bloke I used to know made his own wood rimmed steering wheels from 5mm aluminium plate offcuts he used to get from his place of employment. If you had a plasma cutter you could do a flat one easily, he used to cut them out with a drill and jigsaw as plasma wasn't invented then.
Dale
posted on 27/10/06 at 10:10 AM Reply With Quote
I am doing my wheel in wood trim as its just a cruiser. I started out with an almost 16 inch mgb wheel and cut the outer rim off and rebent the outside rim down to a 12 inch diameter rim and welded it back together. I just need to cut / route out a two piece wood rim.circle and either glue or screw it together. Definately not sva save but should be very vintage looking and free of charge.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
