Author: Subject: Harnesses good supplier
Big Stu
posted on 11/11/06 at 07:53 AM Reply With Quote
Hi all I am looking to invest in a resonable set of 3/4 point harnesses for my Land Rover comp motor. Ideally I would like 3" shoulder straps. Can anyone recomend a good supplier?
Stuart
Phil. S
posted on 11/11/06 at 09:36 AM Reply With Quote
I got Luke ones for my Westy at a very reasonable rate from ebay. They're not 3", but the shoulder straps are. So they're much cheaper than full 3" ones. About £100 for the pair iirc.
[Edited on 11/11/06 by Phil. S]
"The unexamined life is not worth living" (Socrates)
"The unlived life is not worth examining" (Kopp)
chriscook
posted on 11/11/06 at 10:54 AM Reply With Quote
Try LUKE direct - see if they will give you a discount....
MikeR
posted on 11/11/06 at 12:12 PM Reply With Quote
Sabelt direct - do a google, the people in Cumbria. The organised to get mine made, to my spec, in the factory in Italy cheaper than luke etc resellers where doing. Great service & knew exactly what i was wanting when i talked to them. There was a mistake made on the crotch straps, i turned up at a show and they changed the parts there and then (if i'd posted they would have included shoulder pads as recompense.)
