tks
posted on 15/11/06 at 07:52 AM |
VOTES PLEASE! How much ah battery you use?? (BEC only) :P
How much ah and wich type battery?
seems to be that regs need work to be kept cool...
Tks
[Edited on 15/11/06 by tks]
TimC
posted on 15/11/06 at 01:24 PM |
Used a Gel Goldwing battery on the last one. On the MNR I'm planning to use a lighter gel battery.
chockymonster
posted on 15/11/06 at 01:28 PM |
14.8ah drycell battery in mine.
Coose
posted on 15/11/06 at 01:53 PM |
Whatever an R1 uses - 12Ah gel seems to ring true....
Spin 'er off Well...
jimgiblett
posted on 15/11/06 at 04:02 PM |
OE Yam R1 battery (regular lead acid sealed for life) 12ah
- Jim
[Edited on 15/11/06 by jimgiblett]
posted on 15/11/06 at 06:44 PM |
Lighters don't have batteries, I believe they use a Piezo ignition system.
posted on 15/11/06 at 07:50 PM |
well, it only needs a few sparks to get going
DIY Si
posted on 15/11/06 at 08:48 PM |
Mine's a big car battery, at 60 Ah.
Sun Tzu, The Art of War
Locoblade
posted on 16/11/06 at 11:32 PM |
I use an old Yuasa gel 17Ah intruder alarm battery for past 3 years. It has decent bolt through terminals on the top. I have seen 1 of these in a V8
Westy so its not short on cranking power. I have a 24Ah battery in the garage, not tried this one yet. Used a wet battery from a sit on lawn mower for
a year. It worked but started to get at the ali it was sat on.
Rick
marc laptop
posted on 17/11/06 at 07:32 AM |
12ah yuasa std battery been great for 2 years
russbost
posted on 17/11/06 at 10:49 PM |
Car battery, 65 Ah, but I have got 2 bike engines so is that 32.5 each?
