RazMan
posted on 27/12/06 at 07:40 PM |
Door Handles?
I am looking for a pair of door pulls - just realised I can't shut my doors from the inside of the car
Is there anything that is surface mounted but low profile ..... and SVA friendly ?
Any suggestions will be appreciated - I've got my SVA in 10 days
Raz
macnab
posted on 27/12/06 at 07:48 PM |
a length of cord???
DIY Si
posted on 27/12/06 at 07:59 PM |
B&G cupboard door handles? Probably got some spare in the kitchen!
Sun Tzu, The Art of War
Ketchup
posted on 27/12/06 at 08:17 PM |
Hi Raz, car looking sweet btw, congrats fella!
i dont know if one of the flush ally ones at the bottom of this page ...
http://www.connectstores.com/bernards/sp_5992.html
...mounted sideways (oo er) would be any good?
maybe a bit too industrial?!
scottc
How about a leather strap like in the old days
macnab
posted on 27/12/06 at 08:22 PM |
bit of cord...he'll never fail that.
MkIndy7
posted on 27/12/06 at 08:51 PM |
Shame you can't have the rams loose their pressure to close the door and then pump back up to open it... now that would be COOL !
Maybe one for after the SVA operated by the alarm.
RazMan
posted on 27/12/06 at 09:45 PM |
Some novel ideas guys
Bit of cord - too classy Reminds me of my Mini days though
Leather strap - A bit too ...... erm ..... medeavil ?
Cupboard door handles - at least we're into this century with this idea I'll have a look around B&Q to see what they have.
Rams - They already pop under remote control - I just can't pull them shut
Raz
MattCraneCustoms
posted on 27/12/06 at 11:12 PM |
another thought could be the handles above the doors of most cars in the roof lining . . .
just want to say been looking through your archive, thats one cracking looking car. Is it a kit or your own design? I plan to build something similar
when the hicost is complete.
Regards
Matt
RazMan
posted on 28/12/06 at 12:07 AM |
That's a good idea Matt - maybe a trip to my local scrappy is in order.
The car was originally an Aeon GT2 kit but ended up a little different to their intended design. After buying the basic kit I changed every body panel
and I am fairly pleased with the result.
[Edited on 28-12-06 by RazMan]
Raz
jlparsons
posted on 7/1/07 at 02:22 AM |
Quick note - don't do what the delorean monkeys did and put the ashtrays in your gullwing doors
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
stevebubs
posted on 7/1/07 at 03:32 AM |
http://www.morrisminor.uk.com/shop/door-pull-strap-p-234.html
OK.....Neanderthol but functional....
RazMan
posted on 7/1/07 at 11:25 AM |
I thought they were Cocaine dispensers. After all - they had to recall all of the Deloreans because they kept following white lines didn't
they?
Raz
akumabito
posted on 12/1/07 at 12:56 AM |
That's what I was thinking... come in different sizes, materials and colors, and as they were already fitted in cars, they should not give you
any SVA problems..
gottabedone
posted on 29/1/07 at 06:59 PM |
Hey Raz,
The car is looking really good! I missed your post about door pulls. I used the top grab handles from my donor Alfa 33 on my Minari. Instead of
using the full length I cut them down and sprayed them with vinylkote interior spray. They had a metal strap with a small plate at each end. Remove
the plate at one end and cut to length. Reshape the new end for anchor holes, cut plastic cover to length and before fitting bend the new handle to
the shape that you require. They turned out nice and worked well.
Regards
RazMan
posted on 29/1/07 at 10:38 PM |
Sounds ideal Steve - have you got any pics? I've been using Vinylcote for a lot of interior stuff too.
Raz
