Moorron
posted on 4/1/07 at 09:25 PM |
going to make an alloy fuel tank, what guage?
Just removed the nice and shiney s/steel fuel tank from my indy to replace it with an alloy one. Main reasons are to save weight, fit the sender unit
and to add a fuel return for future jobs .
But i need to know if 1.6 alloy is ok or too thin, i can use 3mm also, but if 1.6 will do i can save even more weight.
So, is 1.6 too thin or not?
Many thanks.
Andy.
Sorry about my spelling, im an engineer and only work in numbers.
flak monkey
| posted on 4/1/07 at 09:29 PM |
1.6mm will be fine. Suprisingly strong when all welded up
Sera
http://www.motosera.com
Moorron
| posted on 4/1/07 at 09:32 PM |
great news then, makes it easier to work with. i must b saving about 10kg on the tank alone.
~Cheers~
| posted on 5/1/07 at 12:30 AM |
How big is this tank?
craig1410
| posted on 5/1/07 at 12:36 AM |
18swg (1.2mm) would have done the trick and saved even more weight.
Craig.
John Bonnett
| posted on 15/1/07 at 05:25 PM |
quote
16swg is more forgiving i.e easier to weld
