GO
| posted on 24/6/03 at 02:04 PM |
Obscure dash instrument
Ok, so we all know the trick of using a bigger wheel at SVA to allow a larger area exempt from radius testing etc.
But if you plan your dash layout for a smaller wheel, then when you stick a bigger wheel on for the test, the chances are that something will be
obscured.
Getting to the point... what must be visible from the drivers seat? warning lights, speedo? and what doesn't matter if the wheel obscures
it from view?
skippad
posted on 25/6/03 at 10:53 PM |
obscure dash instrument
My mk got a failure on not being able to read speedo correctly. I had fitted the sierra steering wheel because it was sva friendly. I had
put the instuments centrally in dash, obviously if i had put them in position not to be obscured by sierra wheel it would look crap when a
smaller wheel was fiitted.
As it happens the tester said he would have allowed smaller wheel as long as i could prove the hub ws collapsable and of course no sharp
edges.
I hope this helps
| posted on 27/6/03 at 12:25 PM |
How about an Altimeter. That would be an obscure dash instrument. If you were taller or shorter than the tester and could see the instruments but he
couldn't, would it still fail?.
yours, Pete.
stephen_gusterson
| posted on 29/6/03 at 10:13 PM |
or a compass? a lot of car instrumentation sellers also sell into the nautical market, so its not hard to find one to match!
atb
steve
robinbastd
| posted on 30/6/03 at 09:08 PM |
Thermometer
Got one on my Robin Hood dash. Just in case you don't realise how bloody cold it is.
Used it as my only car for one winter until the novelty of carrying a change of clothing(in case of rain) wore off.
Ian
http://smuttygifts.com/
Wadders
| posted on 30/6/03 at 09:40 PM |
What about a barometer, one of those nice brass and mahogany affairs, old people have in their hallways, tells you what the weather is going to be
like.
Findlay234
| posted on 1/7/03 at 07:47 AM |
You have one dont you.....................? In your hallway?
| posted on 1/7/03 at 09:20 AM |
Artificial horizon.
You could tell whether you are on the level or not. . I bet Morgans come with a barometer option don't they Steve?
yours, Pete.
DaveFJ
| posted on 1/7/03 at 11:58 AM |
you could use the guages off a fiat panda 4x4 - they show pitch and roll.......... hmmmmm
stephen_gusterson
| posted on 1/7/03 at 01:17 PM |
yours, Pete.
Im always on the level
atb
steve
Wadders
| posted on 1/7/03 at 04:32 PM |
Of course dear boy, it sits beautifully between my favorite portrait of the Queen and a trio of flying ducks.
Hang on! are you trying to imply i'm an old git?
i]Originally posted by Findlay234
timf
| posted on 2/7/03 at 01:46 PM |
or even an artificial horizon
DaveFJ
| posted on 2/7/03 at 04:37 PM |
How about these ???
RichyMkIndy
| posted on 7/7/03 at 09:52 AM |
how about a G-meter dont you get those on Evos ? or is Skylines? i cant remeber
blueshift
| posted on 7/7/03 at 11:26 AM |
Skyline R34 has an LCD which will show you all manner of pretty graphs including boost pressure, longitudinal and lateral G (I think) etc.
fun. but who wants the weight of unnecessary electronics? carry a laptop if you want to do testing, then unplug it, pull out the passenger seat,
carpets, bits of fluff for minimum weight
