tegwin
posted on 20/1/07 at 02:34 PM |
SVA and the seat mountings?
Im quite concerned with the seat mountings on my RH 2B...
Basically the seats are supposed to be bolted to the floorpan which is thin stainless sheet...
The outer seatbelt mounts are bolted to the chassis but the middle ones are just bolted to the stainless tunnel walls which are riveted to the floor
so they flex a fair bit...
I am quite tempted to weld a steel bar across the entire width of the chassis to take the seats and the middle seatbelt mounts.
Is there anything in the SVA guide that says how many bolts you have to use to hold the seat down? Im thinking of using two from the middle of the
seats into the bar across the chassis...
Idealy I would like to mount the seats on some runners to allow for me and the old man to adjust the seat so we can both drive it....What is the
slimest adjusting mechanism that would work? (we are both over 6'2" so really need to keep the seats as low as possible...
Chears.
Dunc
posted on 20/1/07 at 02:55 PM |
The seat mounting is less of a problem- SVA manual IIRC says the mounting has to be "adequate"- ie lots of room for interpretation by the
tester. I got away with large repair washers under the bolt into a rivetted aliminium floor.... after all its only got the restrain the seat...
Belt mounting is likely to be more of an issue especially if its into sheet steel rivetted on.... After all, the belt mount will have to take your
weight multipled by whatever G force the impact creates... Personally I would do the proposed welding.... If you've got the welder etc why not
do it? Simpler than an SVA fail and the compulsory retest....
tegwin
posted on 20/1/07 at 03:06 PM |
Yeah, I would deffinately not drive it as it is....I will have to look into what I can do....
Really need some seat runners though, what do other people do when they need low profile seat runners?
Dunc
stevec
posted on 20/1/07 at 03:30 PM |
The Robin Hood forum has mentioned this a few times regarding the 2B.
Search and Ye shall find.
See link to thread.
Steve.
http://community.rhocar.org/index.php?showtopic=12592&hl=seatbelt+mountings
[Edited on 20/1/07 by stevec]
