A Badger
posted on 29/6/03 at 09:20 PM |
Steering Wheel Diameter
I'm planning on building an MK Indy, but before I get started I've got a few jobs (lots) around the house to keep the wife happy.
In return the wife has agreed to help fund the car and leave me alone in the garage to get on with it.
As another sign of good faith she want's to buy me a Steering wheel. The question is how big? I'd like to get a fairly small race type
wheel to give plenty of knee room (and look cool), I just wondered if anybody had found problems with a wheel being too small?
Andrew
chrisg
posted on 29/6/03 at 10:09 PM |
A Badger from my town!
I reckon 10" is too small, 13" is getting a bit big. The advantage of a small wheel is that you can still drive in handcuffs!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
stephen_gusterson
posted on 29/6/03 at 10:11 PM |
beware
a lot of aftermarket steering wheels fail SVA.
Put the car through with the std wheel, and change it afterwards!
Or makes sure the one you get has the SVA compliance
atb
steve
[Edited on 29/6/03 by stephen_gusterson]
zetec
posted on 30/6/03 at 08:29 AM |
I fitted a 11" Mountney one and bought the SVA pad for the centre, passed SVA no probs. Suspect 11" or 12" about right. The SVA
centre pad feel off on the way home so if anyone needs it for their SVA let me know, not worth everyone buying one (£12!) for just a couple of hours
use.
posted on 30/6/03 at 09:05 AM |
The SVA man at Derby stuck some insulating tape over the screw heads on my car and said they were o.k. at that.
yours, Pete.
andyd
posted on 30/6/03 at 09:38 AM |
We're going for a Sparco 270mm (10.5") flat top/bottom one from Demon Twats. About £75 + VAT. Haven't had it delivered yet but
will stick a picture on archive when it arrives.
[Edited on 30/6/2003 by andyd]
A Badger
posted on 30/6/03 at 10:21 AM |
I was thinking of a Sparco Wheel too, like the idea of matching steering wheel, seats, harnesses etc.
Andrew
paulbeyer
posted on 30/6/03 at 12:43 PM |
Another wheel woth looking at is the OMP Formula Quadro. It is flat along the bottom and about 270mm dia. Yours for about £63.09 somewhere in Wibbly
Wobbly Web Land.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
greggors84
posted on 2/7/03 at 04:25 PM |
What are the SVA requirements for the steering wheel?
paulbeyer
posted on 2/7/03 at 11:19 PM |
Fit the donor for the SVA then put on whatever grabs your plums after.
A Badger
posted on 3/7/03 at 10:18 AM |
For the SVA the steering wheel effects things in a few ways.
Firstly it must conform to the standard interior projections rule, therefore all edges must have a minimum radius of 2.5mm.
There must also be no chance of being caught in the steering wheel, so wheels that have slotted spokes and a no no.
The wheel must also offer some form of protection for the diver in the event of a crash. This is partly provided by having a collapsable column, but
can also be provided by some padding over the centre of the wheel.
Finally the wheel defines a zone that is effectively exempt from the interior projections rules. Which is sensible as you would not be able to impact
with switches that are behind the wheel. The exempt area expends 127mm outside the radius of the steering wheel.
Conclusion. Put the donor wheel on for the SVA. Nice and soft, and should give a reasonable exemption area.
Andrew
Viper
posted on 3/7/03 at 11:05 AM |
Seems a lot of you are saying fit the doner steering wheel till after the SVA, Skipad tryed that and he failed because the steering wheel obscuerd the
speedo....take a look at the thread called Oh Bugger in the SVA section...
zetec
posted on 4/7/03 at 08:00 AM |
I was going to use the Ford wheel but also found that to see all the required dials and warning lights I would need to make a new dash after the test!
Also looks better finished to the tester with the correct wheel.
A Badger
posted on 6/7/03 at 09:18 PM |
Well, the wife kept her promise and gave a rather useful aniversary gift.
What was her reaction on opening it??
"Ohh I thought it would be bigger!"
Nuff said!
Andrew
posted on 6/7/03 at 10:49 PM |
Like the wife says.....
How can you expect a woman to reverse park when a man's been telling her that's 9 inch all these years.
yours, Pete.
greggors84
posted on 6/7/03 at 11:10 PM |
Would A Badgers wheel be ok for the SVA? and where can i get a collapsable column from? Or do sierra columns have them?
Chris
The Magnificent 7!
RichyMkIndy
posted on 7/7/03 at 09:38 AM |
On another post there was someone willing to lend out a steering wheel pad or was it this one...
posted on 7/7/03 at 10:05 AM |
The wheel looks o.k. for s.v.a.
It's got no sharp edges or holes. The bolt holes might need plugging or covering. Sierra columns and most other modern columns have a deformable
section that qualifies.
yours, Pete.
zetec
posted on 7/7/03 at 04:22 PM |
I offered the SVA pad but it's for a Mountney.
greggors84
posted on 7/7/03 at 11:40 PM |
Do the metal edges have to me 2.5mm rad (thats the SVA req. right?)
Chris
The Magnificent 7!
A Badger
posted on 8/7/03 at 09:12 AM |
The metal is radiused and is 5mm thick (ie 2.5mm radius), so on that score it should be OK for the SVA, however I would image that the large flat
metal plate itself would be questioned as it does not offer any protection if you head butt it. Not very likely as most cars have full race type
harnesses, but could be an issue.
A pad in matching material wouldn't be difficult to make and could be velcro'ed on for the test.
Andrew
ned
posted on 10/7/03 at 09:30 AM |
thought of starting another thread but this topic seems to cover what i'm about to ask!
I've just been offered these two (mountney) wheels (was gonna choose one of them!) one is 10" and the other is 12". I think the
10" looks too small/badly proportioned. any comments?
My second question is that it is available with a mk2 escort boss, though I'll be using the sierra column for an indy, so are other boses
readily available (where from please!)
Lastly any comments as re sva'able? I've read the previous posts, but got slightly confused about the centre padding and spoke metal
radius thing...
All help apreciated.
Ned.
beware, I've got yellow skin
timf
posted on 10/7/03 at 09:43 AM |
bosses
mountney do bosses for sierra's just got to halfords and pick one up.
the centre section will need padding either buy a pad or make one from foam and cover it then on the way back from sva it falls off.
the 10" wheel will be a bit of a pain go for the 12" one
ned
posted on 10/7/03 at 09:50 AM |
thanks timf.
Anyone else need/want the escort mk2 boss as the guy only wanted a fiver for it!?
Ned.
posted on 10/7/03 at 10:18 AM |
Mine passed with one like that.
At Derby, the tester stuck some tape over the 6 cap screws I had fastened it to the boss with. You could use round headed screws or stick a piece of
foam on with double sided tape. The boss was about £20 from Halfords.
yours, Pete.
