Author: Subject: Steering wheel spacers
pjavon
posted on 5/3/07 at 09:17 PM Reply With Quote
Has anyone used these as i've just fitted new seats and could do with the steering wheel being a bit closer now.
ebay search number:140088240039
Sorry don't know how to do the link, if some one could do it for me pleaase
Always keep a big hammer and a condom in your toolbox, if you can't fix it with the hammer
posted on 5/3/07 at 09:24 PM Reply With Quote
Steering Wheel Spacer
pjavon
posted on 5/3/07 at 09:27 PM Reply With Quote
Ta
RazMan
posted on 5/3/07 at 10:20 PM Reply With Quote
I looked at these a while back - very bling Probably a post SVA mod though.
Raz
pjavon
posted on 5/3/07 at 10:23 PM Reply With Quote
Yeah, seem very cheap compared to rallynuts and demon tweeks so a little concerned about there quality, but maybe worth the chance at that price
posted on 5/3/07 at 10:29 PM Reply With Quote
Yup- I agree re concern re price. Steering is one component I don't take short cuts on.... If that thing fails..............
(says the man whose wheel recently fell off due to inadequate nut torque...)...
RazMan
posted on 5/3/07 at 10:36 PM Reply With Quote
You could always install a QD boss - that will give you about 50mm and you can whip your wheel off as a bonus.
Raz
Humbug
posted on 6/3/07 at 07:28 AM Reply With Quote
to make it even lower cost, you could try loosening up the steering column where the triangular bush thingy is clamped, pulling it up on the spring and tightening up again. I did that and moved it about an inch
pjavon
posted on 6/3/07 at 09:00 PM Reply With Quote
Thanks humbug but i done that when i made the car and i don't think i can let it out anymore
[Edited on 6/3/07 by pjavon]
Mark Allanson
posted on 6/3/07 at 09:10 PM Reply With Quote
Looks like its adjustable on a thread locked by a large lock ring. How embarrasing if that became a bit loose
posted on 6/3/07 at 09:43 PM Reply With Quote
I thought that as well, but I suspect there is a also a grub screw that locks into one of the slots in the center part.
Mark Allanson
posted on 6/3/07 at 10:26 PM Reply With Quote
It would always be in the back of my mind though - makes you shudder to think, gritted teeth and opposite lock.....
