ned
| posted on 24/7/03 at 11:55 AM |
suitable harness?
I have found a s/hand 6 point harness, only problem is that it is from a saloon car and has longer rear/top straps that go behind the seat. Is there
any way this can be used or am I best off staying clear of it and buying a single seater or caterham type with the correct length rear/top straps?
It just seemed a bargain at £20...
Ned.
beware, I've got yellow skin
timf
| posted on 24/7/03 at 12:56 PM |
if it has an aircraft style turn buckle then the sva won't like it much as they tend to have FIA markings but not e marks
also the back straps will be way to long,
don't be temped to shorten them as they are double reversed stiched to prevent them from coming out of the buckles and home stiching isn't
up to the job.
Most racers will tell you that the scrutineers pay particular attention to this due to it being done on a rally car running at the watton airfield
rally a few years ago, the car barral rolled and the seatbelts pulled out of the buckles and the driver was thrown from the car and died. I was chief
safety officer for the event and the ensuing inquest was not a pleasent experience for me or the scrutineers in question.
As with most things safety wise it doesn't always pay for the cheapest option as you don't always know the history of the parts. All
seatbelts should be replaced after an accident as they would be streched beond their safety limits.
ned
| posted on 24/7/03 at 01:00 PM |
thanks for the info timf, i agree safety is paramount, but i do like my bargains....
i'll give it a miss....
Ned.
| posted on 24/7/03 at 02:31 PM |
You can use long belts by putting mounting plates low down in the boot area to use up the excess and sling them over a round bar across the roll bar
at a suitable height or through the cutout in a highback seat. 6 point harness sounds a bit extreme, where do all the straps go?
yours, Pete.
timf
| posted on 24/7/03 at 02:33 PM |
yours, Pete.
nut crackers and end up with eyes like your glasses
[Edited on 24/7/03 by timf]
ned
| posted on 24/7/03 at 02:35 PM |
the bottom belt is like an upside down V shape that goes between your legs and then through a hole in the seat normally...
Ned.
timf
| posted on 24/7/03 at 02:36 PM |
as i said ned, nut crackers
ned
| posted on 24/7/03 at 03:29 PM |
yeah, ok then smarty pants: 'nut crackers' it is...
...though when it's done up it feels more like a rock climbing/abseiling harness does if you've ever worn one of them?!
Personally I've never worn any nutcrackers....
Ned
| posted on 24/7/03 at 03:40 PM |
Ned
You just don't get asked to the right parties...
DJ
timf
| posted on 24/7/03 at 03:42 PM |
having heard someone hit the armco at the pit slip road at sneterton wearing a 6 pointer (not correctly adjusted) he submarined in the harness hence
the term nut cracker .
ned
nobody loves me....
andyd
| posted on 24/7/03 at 07:27 PM |
Tim, this is not true. I rang Norwich SVA test centre today regarding mirrors (another thread on here) and also asked the guy about the belts. I
wanted to know if an FIA approved 4 point would pass. He said yes so long as it was fitted correctly. I asked specifically about the quick release
buckle and he said it would be ok so long as you can undo it with one hand. As far as I know (only worn one once in a formula ford) that is the case.
No E markings are necessary as long as the equipment satisfies all the criteria that the E mark is awarded for on E marked gear. Make sense?
The only problem is that the FIA ones are more money than the clunk-clik style. Hey ho we must have the toys though eh?
Rorty
| posted on 25/7/03 at 06:44 AM |
Ned, if you're proposing a lot of track use, then it may be a bargain. If though, you'll be using the car mostly on the road, you'll
get sick and tired of having to put on the 6 pointer every time you jump in. They should be replaced a minimum of every two years. Is that the reason
it's being unloaded?
You don't necessarily need to put the snap-in/bolt-in fixtures back onto the rear straps. It's perfectly acceptable to wrap them around
part of the cars structure, and use the steel sliders to thread the webbing through. A lot of racers use this method, and is generally accepted as a
better option in many cases, as the webbing doesn't have such an acute fold in it.
Whatever method is chosen for mounting a harness, the shoulder straps must go down rearwards at an angle of about 45 degrees. Going straight
back is a no-no!
Similarly, the crotch strap must be attached to the chassis in line with the outer lap belt mounting points (which should be behind the line of the
back of the seat).
Cheers, Rorty.
