blakep82
posted on 20/4/07 at 10:57 PM |
seat belt mounting concerns
here's another one for you!
the SVA book says
quote: Threaded bushes should be welded (at both ends) through the tube, and not be end mounted on the surface
but i don't have threaded bushes, I have seatbelt harness eyes welded rights on to the tube, and not welded through.
the thing is, my chassis is a ex-race chassis, and if its good for racing, surely its good for SVA?!
what do you think? am i reading the SVA book wrong? or how can i prove its good for hitting concrete walls on an oval at well over 150mph?!
________________________
Ketchup
posted on 20/4/07 at 11:02 PM |
i have harness eye bolts welded into tube then welded to 3mm thick plates and they passed sva with no probs earlyer this month
blakep82
posted on 20/4/07 at 11:05 PM |
have you got any photos? I'm not sure how you mean, do the eye bolts go all the way through the tube? mine don't
I'll try and put some of mine up tomorrow
Ketchup
posted on 20/4/07 at 11:08 PM |
mine dont go all the way through either, i just left them proud of the tube by 4mm and filled the gap with weld
Ketchup
posted on 20/4/07 at 11:10 PM |
another.. sorry pics are huge an not very clear!
Mr Whippy
posted on 20/4/07 at 11:11 PM |
Are toggle switches ok for racing? What about mirrors, visibility etc, the two are totally different, what may pass race rules doesn't mean it
will pass the SVA.
For the SVA the harness eyes must be at least 8.8 hardness and a standard thread. Simply welding them on means that the entire load is taken by that
weld and on amateur built cars that could be any quality. So they will expect it to be going through the tube, that the tube won't crush and it
has a proper nut on the end.
blakep82
posted on 20/4/07 at 11:19 PM |
^ yep, racing and road are different, mirrors are not so important, and switches etc don't come into it, but as for the strength of seatbelt
mounts, forces and speeds in racing are much higher, so thereofre the mountings should be stronger.
also, put like that, the mounting's in ketchups photos are also just relying on the strength of the welds, albeit more surface area of weld
anyway, here's mine
seat belt eye
[Edited on 20/4/07 by blakep82]
Ketchup
posted on 20/4/07 at 11:39 PM |
tube wall thickness is 4mm, machined overhang of 8mm halfway down tube, and its welded both sides of the plate. i know its down to the strength of the
weld for safety, i think that things would bend before the weld fails. lets hope i am good enough ay, im not a professional welder! (that prob shows
in the pics )
[Edited on 20/4/07 by Ketchup]
