jdgar
posted on 6/5/07 at 10:58 PM |
buidl shed finished-build started
Well the new shed is finished enough to start getting the work bench in
and get the chassis in, and out from under the porch. It felt really good
to get the car in. It felt so good that I put in the rear axle. Still
have to bolt it up and get it adjusted.
BEST NEWS-----my little 5000BTU $89 Wal*Mart Air conditioner works
GREAT! It has been typical Oklahoma spring weather--84 deg and 70%
humidity today and the shed is 67 deg!!! I look forward to a comfortable summer build!!
Now to figure out the front suspension!!
Joe Garrison
"If it 'ah one ting, is a nex'.
Avoneer
posted on 7/5/07 at 07:33 AM |
Sounds too cosey for a build garage!
Well done anyway.
Pat...
Ivan
posted on 7/5/07 at 09:04 AM |
Joe Garrison
Is that -84F or -64C
No wonder you need a Build Shed - bet you don't use an open top much in winter
For winter driving you don't need to weld the chassis - just glue it with water
jdgar
posted on 8/5/07 at 12:48 AM |
"Is that -84F or -64C
For winter driving you don't need to weld the chassis - just glue it with water "
Sorry-------- I was trying to show temp as +84F deg Thank God the winters aren't that cold here. Sun gets pretty hot with open top in
summer though. Usually about + 102F by mid June. Hence the air conditioning.
