Author: Subject: Steering Wheel Size ?
Kosmo
posted on 18/6/07 at 12:52 PM Reply With Quote
What size steering wheels are most people using ?
Also, will a quick release bose pass SVA ?
Cheers, Kosmo.
twybrow
posted on 18/6/07 at 12:54 PM Reply With Quote
I think most use s stock Sierra wheel for SVA, then change post-SVA to smaller/quick release.
iank
posted on 18/6/07 at 01:26 PM Reply With Quote
320mm (ish) seems popular, some have failed on the standard wheel as it's too big for the tester to get sat properly.
Quick release can pass, but only if 1. there is still a collapsible element in the column and 2. if it can't be detached while the car is in motion i.e. if it needs a key to remove it's fine, pull button will fail. Having said that I'm waiting till post SVA to avoid tester randomness on subtle issues like those, think hassle reduction exercise.
Anonymous
whitestu
posted on 18/6/07 at 01:48 PM Reply With Quote
320mm
Tried a 300mm and found it too small
Stu
Humbug
posted on 18/6/07 at 01:56 PM Reply With Quote
11" (280mm) which is OK on my setup - 1.4 K-series - only a bit heavy if you try to turn while going at less than about 5mph
posted on 18/6/07 at 03:36 PM Reply With Quote
320mm here too....
DarrenW
posted on 18/6/07 at 03:58 PM Reply With Quote
Mine is about 330mm and feels OK. Im looking for a suede 300mm at the mo. Dont like the 10" etc wheels. 12" is about the smallest id like to go.
Chenti
posted on 18/6/07 at 07:51 PM Reply With Quote
i have a 10" wheel, it takes some getting used too.
looks awesome though
stevebubs
posted on 18/6/07 at 09:52 PM Reply With Quote
Merlin Part number 23SBAB
12" Mountney 3 spoke alcantara.
Mine's the 11in. Don't have any issues with steering heavyness but don't have a quick rack
