Author: Subject: Finicky Seat Runners
Avoneer
posted on 4/7/07 at 05:55 PM Reply With Quote
They are being right arses.
I've bolted them to the seats and when I nip them up tight under the car, they don't want to run anymore.
Had a good play and it's because they twist when nipped up every so slightly - approx 1mm - but it makes all the difference.
Any suggestions?
Pat...
tegwin
posted on 4/7/07 at 06:31 PM Reply With Quote
I have the same problem on my car...
I figured if I put penny washers between the floor and the seat runners to give the slide a bit more space...it seems to work a bit better...still sitff but it does actually slide
Avoneer
posted on 4/7/07 at 07:12 PM Reply With Quote
Tried that at first as I thought the middle of the seat was catching on the floor of the car - but that wasn't the case.
I need to try and level them on the base of the seat as they both tilt in slightly.
Pat...
omega 24 v6
posted on 4/7/07 at 08:48 PM Reply With Quote
Could you try to fit them up loosely with a bed of epoxy glue. the retap the holes and fit the bolts after it's hardened??
Avoneer
posted on 4/7/07 at 09:15 PM Reply With Quote
Good point.
Even body filler may do it.
It's just to level up as such.
Pat...
Avoneer
posted on 4/7/07 at 09:27 PM Reply With Quote
Second thoughts, If I use 3mm thick bar across the seats (mounted in-between the runners and seat base), the runners should have a flat plate to sit on - will try that tomoz.
Pat...
