theohighland
| posted on 22/7/07 at 09:37 PM |
photos of your seat belts please!
I'm looking to do the seat belt supports on my chassis soon and want to know how people have fitted their seat belts.
I'm using normal road car seat belts from a rover, not harnesses.
Thanks, Theo
ReMan
| posted on 22/7/07 at 09:41 PM |
Are you building a 7 type?
I wouldn't fancy just a diagonal holding me in IF I tipped it up!
theohighland
| posted on 22/7/07 at 09:44 PM |
yeah I am, I do have harnesses as well but they go in to one at the back and ar very long so wasnt sure if they'd be allowed, am I wrong?
ReMan
| posted on 22/7/07 at 09:50 PM |
Like this?
Don't see why it should be a problem as long as it works OK fits round your seats and is the right height for SVA.
I'm sure others have used them........awaits response
zxrlocost
| posted on 22/7/07 at 09:59 PM |
hi if youve got the ones above you probably have standard size ones and need 7 style harnesses
theohighland
| posted on 22/7/07 at 10:00 PM |
yeah i do have the ones above, does that mean I cant use them?
ReMan
| posted on 22/7/07 at 10:15 PM |
Don't know why?
Is the top mount too long?
I guess saloons have this on the roll cage somewhere near the rear window
If this is the case, I'd still look at getting a replacement harness rather than the belts you have.
Apologies if anyone is using them in a 7, but I think they'd look odd and as said you really need holding in, unless you're not bothering
with a roll bar, in which case your probably better of without belts at all
[Edited on 22/7/07 by ReMan]
zxrlocost
| posted on 22/7/07 at 10:16 PM |
you cant the proper thing off ebay
kit car harnesses for about 40 quid
afterall itll cost you that much for a SVA retest
theohighland
| posted on 22/7/07 at 10:32 PM |
ok thanks guys, i'll have a look for the other types
Cheers, Theo
theohighland
| posted on 22/7/07 at 10:39 PM |
ive just found these on ebay, but they dont say anything about being safety approved etc, how will i know if they'll pass an sva?
http://cgi.ebay.co.uk/Pair-Of-Brand-New-4-point-harness-harnesses-Blue_W0QQitemZ330149416485QQihZ014QQcategoryZ72228QQtcZphotoQQcmdZViewItem
thanks, Theo
ReMan
| posted on 22/7/07 at 10:58 PM |
You don't.
Why not look elsewher
Even
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=SAB901076N/1
have them at that sort of price without trying, and you know they will have a proper label on them!!
James
| posted on 23/7/07 at 10:26 AM |
My car was built on a relatively tight budget, but at the end of the day, your life depends on the seat belts and, although others may disagree, I
believe my life is worth £90 for a pair of new 4-points from MAC1!!!
If I'd know then what I know now, I'd have bought 5-point belts and had another chassis mount so that I couldn't
'submarine' in a front-ender.
James
- Muhammad Ali
| posted on 23/7/07 at 11:24 AM |
James
I'd also have gone for 5 point harnesses to stop the lap part of the harness riding up when you tighten the shoulder straps which can get quite
annoying.
I would not feel safe/comfortable in a 7 wearing a normal 3 point inertia type seat belt either.
