Author: Subject: Gear Lever Knob
The Doc
posted on 4/8/07 at 05:46 PM Reply With Quote
Gear Lever Knob
A few people seem to have failed on the radius of this.
How come? What's the radius stipulation?
posted on 4/8/07 at 06:17 PM Reply With Quote
Used the standard Sierra knob as I'm sure others have ,with no problems
worX
posted on 4/8/07 at 07:00 PM Reply With Quote
I think it's <2mm is a fail, but not sure now...
actually it might be <1.5mm
Marcus
posted on 6/8/07 at 11:37 AM Reply With Quote
I'm one of the fail people!
I used an aluminium knob with the flat top for a badge from Europa. Failed on the radius at the transition between the 'ball' and the flat top. Replaced it with a spherical knob for the retest - now has the dodgy one back on!
This was the first thing the tested noticed (the tested was being tested at the time too which didn't help!).
Once I knew it had failed, the rest of the test was much less stressful!
Marcus
Because kits are for girls!!
posted on 8/8/07 at 09:50 AM Reply With Quote
yep - same here - the top has a cut in for the central emblem with flashing LEDs*. - the sharp edge fais the radius.
I made my own from a bit of wood and spray painted it - look quite good (but fitted original one back on)
* I didn;lt buy it and the battery no longer works so no flahsing.
