New Topic New Reply
Author: Subject: MK Harness bolts
MK9R
posted on 15/9/03 at 01:59 PM Reply With Quote
MK Harness bolts
I noticed at donno that the threaded tubes for the harness bolts have been beefed up with some plate to create a web between the tubes and chassis. Is this related to a thread i read on here about an MK Indy failing SVA because of this, altyhough Martin did speak to the test centre (and Swansea) to sort it out? Just a bit worried about my older chassis that doesn't have it.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 15/9/03 at 02:01 PM Reply With Quote
Hi Austen,
Just so happens I took a couple of pics of the mountings to show the SVA man as I think they will be covered up after I panel the interior. I've put them in my archive, hopefully there of some use.
Nick
loafersmate
posted on 15/9/03 at 04:03 PM Reply With Quote
Mine passed fine at Beverley in July, no gussets.
Ben
skippad
posted on 15/9/03 at 10:29 PM Reply With Quote
mk harness bolts
It was my indy that was the centre of the seat belt anchorage contraversy back in June. Martin came to some agreement with Swansea to apease the situation and the testers decision was overuled.
Thats why the extra "bridge" has been added, though i don't know how this will affect home built chassis. Again it seems all down to individual testers and stations.
redeye
posted on 17/9/03 at 07:47 AM Reply With Quote
does anyone know where mk get their threaded tubes
i need some for my harness
cheers.
posted on 17/9/03 at 01:07 PM Reply With Quote
Redeye,
I think they drill out some round bar and then tap the hole to suit.
Nick
redeye
posted on 17/9/03 at 02:30 PM Reply With Quote
how do u tap the hole
is this easy to do???
Simon
posted on 17/9/03 at 03:36 PM Reply With Quote
Redeye,
Hold the round bar in a vice, and drill though with correct size drill bit.
Then run through with a tap.
You may find it easier to buy some threaded tube instead.
Simon
ned
posted on 17/9/03 at 03:54 PM Reply With Quote
Be careful if you intend to weld it on (how else would you!) that the heat doesn't distort the thread, leave a bolt in it, this should help...
Ned.
beware, I've got yellow skin
mad-butcher
posted on 17/9/03 at 05:34 PM Reply With Quote
oh eye leave the bolt in case harden it snap it trying to get it out redrill and tap out............. weld it on and then clean the threads up with a tap
MK Goldrush
posted on 17/9/03 at 09:52 PM Reply With Quote
All this tapping
... all this tapping? Have I wondered into a Fred Astair Appreciation Society or a Kit Car Builders Forum?
Mad... sounds like you speak from experience!
redeye
posted on 18/9/03 at 11:14 AM Reply With Quote
mad-butcher
are u saying that it NOT a good idea to leave a bolt in?
timf
posted on 18/9/03 at 12:32 PM Reply With Quote
i always found the best way to drill and tap round bar was with a lathe then when welding it in make a mushroom of modelling clay so that no weld spatter can get in the treads once done pull out the clay and run a tap through the treads again.
the method with the bolt in can result in a broken bolt and then you have to start all over again but with the disadvantage that the thing is now welded to somthing large and difficult to handle
[Edited on 18/9/03 by timf]
posted on 18/9/03 at 12:51 PM Reply With Quote
I started the thread until I reached the end of the tapered bit of the tap. Then, after welding, I finished it off.
DJ
MK9R
posted on 18/9/03 at 12:55 PM Reply With Quote
I started this thread off, and it got totally hijacked!
Cheers Austen
RGB car number 9
www.trackace.co.uk
redeye
posted on 18/9/03 at 01:33 PM Reply With Quote
erm...............sorry?
posted on 18/9/03 at 01:59 PM Reply With Quote
Badger, badger, badger, badger, aagh snake, aagh snake.
yours, Pete.
I'll get me coat.
mad-butcher
posted on 18/9/03 at 06:22 PM Reply With Quote
mine ain't renforced either but i seem to remember an mk in a crash last year front corner torn off BUT NO BREAKAGES AT THE ANCHORAGES
tony
Rorty
posted on 19/9/03 at 07:30 AM Reply With Quote
redeye:
Don't get any of your bolts or nuts hot (unless you can guaruntee you'll remember to throw them out immediately), as they will lose their set.
Heating up a grade 8 bolt for instance will render it about as much use as a stick of celery. Not what you want to trust your life to.
I keep a tin of bolts I use in my jigs for welding suspension parts etc. I round the hex heads off with the grinder, so I can just tighten them enough in the jigs, but no one can use them for any thing structural.
With regard to the welded threaded bushes, cut the thread initially with the first tap, weld the tube, then finish with the second and/or third taps.
Cheers, Rorty.
posted on 19/9/03 at 12:40 PM Reply With Quote
Whilst we're on the subject of tapping, is the tap twisted in or hammered of a bit of both? and does one tap do all the thread or is it stages?
RoadkillUK
posted on 19/9/03 at 12:51 PM Reply With Quote
A quick 'Google' resulted with THIS
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
The One
posted on 21/9/03 at 12:01 PM Reply With Quote
Has any body considered the fact that these bolts are a special non-standard thread and the taps are very expensive ?? If any body would like any thing like this making then please u2u me
posted on 24/9/03 at 10:08 AM Reply With Quote
What thread are these bolts/tubes?
I didn't know they were non-standard till you mentioned it, but now you do I can't find any bolts to fit!!!!
Nick
mk blade
posted on 24/9/03 at 04:02 PM Reply With Quote
Had to tap holes out so bolts went in smoothly after chassis had been powder coated.
Took a bolt to local nut and bolt supplier and when i asked for a tap to clean out seat belt mounting bolts he told me they where 7/16 UNF. Got tap and clean out holes, just takeing off powder coating no metal.
Bolts now screw in all way by hand.
Tony.
New Topic New Reply
