Author: Subject: Copper fuel pipe
givemethebighammer
posted on 26/9/03 at 07:41 PM Reply With Quote
Copper fuel pipe
considering using 8mm copper microbore (central heating) pipe for fuel on my car.Only running carbs so no need for high pressure stuff. What does Mr SVA (or MOT) for that matter have to say.
The pipe in question meets and exceeds
BS 2871-2 1972, BS 2871-3 1972
and is EN 1057 Table W annealed rated
all Dutch to me
In addition to this is copper suitable for petrol. I would have though so because a friend of mine bought some replacement pipe for his Cavalier 4 x 4 turbo from Vauxhall and this was soft (hand formable) copper stuff ?
any thought ?
thanks
Mark Allanson
posted on 26/9/03 at 08:52 PM Reply With Quote
I have no personal experience of copper petrol pipes (all production cars have steel or plastic), but the last time this was discussed, it was decided that copper reacts with the petrol and causes them to sulphur up or something else equally nasty.
posted on 27/9/03 at 07:37 AM Reply With Quote
I did a bit of Google research on this: there's only a problem if you use low-grade '3rd-world' petrol full of sulphur in copper pipes.
Petrol to European standards doesn't have the same problem.
givemethebighammer
posted on 27/9/03 at 12:24 PM Reply With Quote
Our petrol being OK would match up with Vauxhall using it. But what about MR SVA
I can only find the following:
The fuel system, including the tank and filler cap, pumps, filters, pipes and pipe
connections, will be checked for leaks, security, suitability for their purpose, and
positioning.
Particular attention will be paid to the positioning of components to minimise fire risk.
Every component must be securely fitted, made of suitable materials, protected as
appropriate from corrosion and heat.
Thought I had read somewhere about appropriate markings ?
posted on 27/9/03 at 01:09 PM Reply With Quote
My car passed 3 years ago with aforementioned 8mm pipe and has had no problem with it since.
yours, Pete.
givemethebighammer
posted on 27/9/03 at 02:00 PM Reply With Quote
Thanks Pete,
Did you flare the ends to connect to the rubber hose or did you us some other type of connection ?
posted on 27/9/03 at 04:54 PM Reply With Quote
I just used compression clips as there is only gravity pressure till the block mounted fuel pump. I use an inline filter in the hose leading to the pump from the copper pipe and it has only blocked once due to welding residue from the home made tank.
yours, Pete.
givemethebighammer
posted on 27/9/03 at 07:41 PM Reply With Quote
Thanks, I will either flare the ends or solder some plumbing compression rings on
Inline filter forgot about that one.
VinceGledhill
posted on 29/9/03 at 04:19 PM Reply With Quote
I used the 10mm mico bore on a previous project. No problems at all. Didn't flair the ends or anything. Just used clips. Was OK and passed SVA no problems. Just make sure you put enough proper clips in it and clip it to the chassis. Clips no greater than 30mm appart.
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
posted on 29/9/03 at 06:13 PM Reply With Quote
do you mean 30mm or 300mm vince? thats a lot of clips...
theconrodkid
posted on 29/9/03 at 07:10 PM Reply With Quote
12" in old money
who cares who wins
pass the pork pies
VinceGledhill
posted on 29/9/03 at 08:37 PM Reply With Quote
OOps.... Old Money.... I remember pre decimalisation.... Yeah.... 12 inch or 30cm 300mm or 1/234 of a fathom... 16th of a chain or whatever.
Clip it so it "dunt" rattle abart.... Best Yorkshire Accent adorned
Regards
Vince Gledhill
givemethebighammer
posted on 29/9/03 at 09:21 PM Reply With Quote
bought some pipe today,
A quick experiment with a flaring tool (my brake pipe set from Lazer can flare pipes up to 1/2 '' ?), proved successful. So there is a job for the weekend.
ps I have a bag of 100 "p clips" so will probably fix it every 200mm anyway.
thanks
MK Goldrush
posted on 30/9/03 at 11:44 AM Reply With Quote
Half a cock if you're a real Yorkshireman!!
