chris taylor
posted on 20/11/07 at 06:38 PM |
Harness mountings
Guys, some advise please, currently looking at some 3 point harnesse where the top mounting is the clip type.
The bottom 2 mounting holes are bolt in and my question is will they pass SVA with a clip type top mounting,
cheers, Chris
nitram38
posted on 20/11/07 at 06:51 PM |
They will pass with either provide that there are no sharp edges and the bolts/eyes are marked 8.8 grade or above.
russbost
posted on 20/11/07 at 07:35 PM |
What Nitram said - min 11mm bolts
posted on 21/11/07 at 09:56 AM |
^^^^ or imperial equivalent of 9/16 (UNF usually)
Black Cat
posted on 24/11/07 at 10:12 PM |
On the same subject as harnesses, I need to fix mine to a horizontal member that I have welded on to my roll bar. The question is can I just weld a
nut to the bar or have I got to weld a threaded tube into the bar?
Regards Steve
Marcus
posted on 26/11/07 at 12:43 PM |
ISTR it has to be the threaded bush due to possible bending moments distorting the tube.
They are available from MK and probably others. I used these with no problems (except drilling 22mm holes in my roll bar - had to bring to work!!)
Marcus
Because kits are for girls!!
Black Cat
posted on 26/11/07 at 07:14 PM |
Thanks for that Marcus.
Will try their web site.
Regards Steve
