peterparsons
| posted on 21/11/07 at 07:48 PM |
Question on Seatbelt mounting points
Do the seatbelt mount point nuts need to be welded to the chassis or will nylock's be OK for the SVA ?
Mal
| posted on 21/11/07 at 08:13 PM |
Nuts
I believe they need to be welded,
but I don't have access to an SVA manual to proove it.
Mal
speedyxjs
| posted on 21/11/07 at 08:34 PM |
I think they need to be welded so they are effectivly part of the chassis
robinj66
| posted on 21/11/07 at 09:05 PM |
I don't think they necessarily have to be welded but you have to be able to undo them from the driver's seat ( or something like that)
which effectively means you can't use loose nuts under the floor etc
| posted on 22/11/07 at 07:56 AM |
Yes captive nuts are require --- use proper ones don't just weld an ordinary nut on.
Syd Bridge
| posted on 22/11/07 at 10:35 PM |
You can use a 'bolt and nut' where you can get access to the nut. Captive nuts are NOT mandatory.
From the SVA manual....
"...The bolt may be secured into an alternative fixing, eg a locknut of suitable strength, where access is provided to the 'rear'
of the mounting to enable separation/re-attachmentof the belt"
From Section 5 of the manual.
Bolts (and nuts) have to be 7/16 or 11mm high tensile. and clearly marked as such.
Syd.
dnmalc
| posted on 23/11/07 at 09:00 PM |
Hi I was thinking of making the nuts up out of some hex bar and welding this to the chasis with spreader plates. while the bolts have to be of a
specific grade of steel is there any regulations on the nut
