t.j.
posted on 12/1/08 at 07:52 PM |
anchorage strenght minimum thickness
HI,
Q: My nose off the sierra differential wil be mounted in a triangulation at the rear of the tunnel.
This triangulation will also contain the anchorage nut for the seat-belt.
What thickness would you use?
4 mm? or could 3 mm be sufficient?
thnx
tks
posted on 12/1/08 at 08:01 PM |
it depends on how the forces will be acting on the sheet.
if its sideways you will need thicker sheet then if its lenght wise..
tks
posted on 12/1/08 at 09:11 PM |
if it isn't much sheet i would use 4mm.
also its different if the forces are pushing on the sheet or pulling.
pulling=thinner
pushing = thicker
tks
t.j.
posted on 12/1/08 at 09:27 PM |
As it will be the lower behind the seat the forces will be in lenght, so in the triangulation and not sideways
I will use 4 mm for safety. I don't want safety-belts which can't do their job.
Thx
[Edited on 12/1/08 by t.j.]
