Author: Subject: Seatbelt tophat mounts?
tegwin
posted on 13/1/08 at 05:23 PM Reply With Quote
I have Sabelt 3 point harnesses....
They sit on (roughly) 11mm bolts, but the holes in the belt are more like 25mm....
I have two adapters that look a bit like top hats fitted to the drivers side...
But I dont have another pair for the passenger seat..Can you buy these from anywhere?
worX
posted on 13/1/08 at 05:25 PM Reply With Quote
I don't know the answer to that I'm afraid, but I'm sure you could turn a couple pretty easily!
Paul (Notts)
posted on 13/1/08 at 05:42 PM Reply With Quote
Thinking outside the box a little - Do you only need one top hat thingy on each side ?
Paul
tegwin
posted on 13/1/08 at 05:46 PM Reply With Quote
Yes, one top had thingie on each side..
And yes, you could turn a pair very easily....unfortunately I dont have access to a lathe which sucks!
I was just curious if they were standard parts or not...
adithorp
posted on 13/1/08 at 06:03 PM Reply With Quote
You'll find them on the door pillar belt mounts on any car down at the scrap yard.
adrian
nib1980
posted on 13/1/08 at 06:30 PM Reply With Quote
I've got a bucket full of seatbelt bolts at work, got apiccy? or a digram with dims on? I suspect the thread is 7/16th
